73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Diesel Engine Discussion => Topic started by: C-Moore502 on January 04, 2010, 09:50:56 am
Title: 84 6.2L Diesel Sending Unit
Post by: C-Moore502 on January 04, 2010, 09:50:56 am
I wanted to know if I have to put the 2 outlet that cost an extra $100 or if I can use the other 3 outlet unit.   says the 2 outlet but I wanted to be sure. Thanks.
Title: Re: 84 6.2L Diesel Sending Unit
Post by: Captkaos on January 04, 2010, 11:04:08 am
From where?  The Diesel should be a 2 outlet.  If you block off the 3rd one it should work though.
Post by: C-Moore502 on January 04, 2010, 11:49:15 am
I was looking around for a good price.
Post by: Mr Diesel on January 07, 2010, 11:20:47 pm
I bought mine here for about $70 each plus shipping.
http://www.quantaproducts.com/products.asp?dept=332&pagenumber=2&sort_on=&sort_by= (http://www.quantaproducts.com/products.asp?dept=332&pagenumber=2&sort_on=&sort_by=)
The one they show has the third port for removing water from the tanks. You can just block it off. The later models used only 2 ports.
