73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: carson on January 12, 2010, 11:26:13 am
Title: Wheel/Tire sizes
Post by: carson on January 12, 2010, 11:26:13 am
I want to be sure before I pull the trigger that this setup will work, so if someone will please double check me I would appreciate it.
1975 Blazer 4wd stock height. I will lift it a small amount if I have to. (Can you use blocks on the front?, or I've got the rear springs from    a 1982 2wd halfton if that would be of any use)
Wheel, Soft 8, Steel, Black, 15 in. x 10 in., 6 x 5.5 in. Bolt Circle, 4 in. Backspace
Tire, Super Swamper LTB, LT 33.00 x 13.50-15, Bias Ply, 2,270 lbs. Maximum Load, Blackwall
Lug Nuts, Conical Seat, Bulge, 1/2 in. x 20 RH, Open End, Zinc Plated Steel
I'm new to the 4x4 scene, so any and all help is appreciated.
Title: Re: Wheel/Tire sizes
Post by: frogman68 on January 12, 2010, 12:13:00 pm
Not sure on most of it but NO blocks in on or near the front axle...
Post by: Captkaos on January 12, 2010, 01:41:27 pm
You might rub a little on the lock to lock with the 13.5' and 10" rims, but you may be ok.
Post by: three8six on January 12, 2010, 03:03:43 pm
yea no blocks in front please
