73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: krazylunatic on January 13, 2010, 01:58:23 pm
First off for some reason my right turn signal does not blink, it just gets brighter and stays like that till a turn it off, i hear no bliking in the cab either. Any clue what could cause that?
Second, nomrally my gas gauge and volt and oil pressure gauges all work. The other day I went to to look at a truck and they all worked fine. Left to test drive the other vehicle and when i got back and went to leave. The guages wouldnt light up at all and they did on the way there and none of them worked at all. Any clue?
as far as the turn signal, check all bulbs on the right side of the truck and make sure they work.
for the instrument panel, maybe a ground came loose or disconnected?
Yeah what he said
Is the dimmer turned down?
all the bulbs work and no one the dimmer, they worked perfect going up to see the guy and when i came back after test driving the other vehicle there didnt light up or anything and i messed with the dimmer
the dimmer part of my headlight switch kinda did the same thing, except i could get the interior lights to work if i played with it enough. i replaced it and everything worked after that.
now the turn signals, there could be a bad ground on one of the bulbs. one of the wires may be frayed through, and shorting out on the body/frame.
