73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: frickenbored on March 10, 2010, 03:56:08 pm
Title: 14 Bolt Full Floater
Post by: frickenbored on March 10, 2010, 03:56:08 pm
So I've been looking for a 14 bolt rear axle for my 1988 K5 Blazer 4x4.  I finally found one on craigslist, a 1970 semi-floating 14 bolt from a pickup.  My k5 currently has a stock 10 bolt.  How hard is it to swap these two axles?  Are all the brackets in the same place or will I have to do some major fab work to get that 14 bolt under the truck?  Thanks for any help.
Title: Re: 10 bolt to 14 bolt
Post by: Captkaos on March 10, 2010, 05:30:06 pm
is it a 1970 model or 70's model.
Post by: frickenbored on March 10, 2010, 05:59:54 pm
its out of a 1970 3/4 ton chevy pickup
Post by: Captkaos on March 10, 2010, 06:09:45 pm
If it is under a 70, I would measure it first.  Does it appear that the perches were moved.
Post by: fitz on March 10, 2010, 07:00:12 pm
  Keep in mind that there are 2 different spring perch widths on the 14 bolt when you are talking 73-87 chevys. 1 is for the 3/4 ton and the other is for the 1 ton.
  I sold a guy a 14 bolt from an 83 1 ton and he claimed that it had the correct perches for his 71 3/4 ton.
  If he was right in theory that 70 you are looking at may have a 1 ton 73-87 14 bolt in it. If thats the case you would need 1 ton spring perches to make it work in your blazer.
  A 14 bolt from a 73-87 3/4 ton is what you want. It will have the perches in the right spot.
 I hope this all makes sense.
Post by: frickenbored on March 10, 2010, 07:30:35 pm
I havent actually seen the axle yet so I don't know if the perches have been moved.  I plan on going to look at the axle this week so I'll measure my 10 bolt perches and see if the 14 bolt is the same.
How hard would it be to move the spring perches?  would the shock mounts also have to be moved?
Post by: Chevalade on March 10, 2010, 09:43:15 pm
You should try to find a full floater. Much better axle.
Post by: Irish_Alley on March 10, 2010, 10:16:20 pm
Would a semi floater even be under a 1 ton?
Post by: Blazin on March 10, 2010, 10:35:38 pm
If its a semi floater its not original to a 1970. Its 81 / 82 ish or newer. Agreed I would wait for a full floater.
Post by: frickenbored on March 11, 2010, 05:38:56 am
well the reason I like the semi floaters is because their 6 lug.  But the craigslist ad says its 8 lug so I don't think the guy knows what he has.
Post by: Irish_Alley on March 11, 2010, 09:01:19 am
They make a 8 lug semi. Had a 83 8 lug semi out back and 10 bolt up front
Post by: Chevalade on March 11, 2010, 09:01:33 am
Semi floaters also have a beter chance of strandin ya on the trail.
Post by: fitz on March 11, 2010, 06:11:34 pm
The 14 bolt 6 lug semi floater is from the 88+ (newer style) trucks.
A 14 bolt FF from a 73-87 3/4 ton should be easy to find for $100 or so on craigslist.
Post by: frickenbored on March 11, 2010, 08:52:24 pm
Yeah, I think I'll just keep searching for a FF.  Can you buy front 10 bolt axle shaft that are 8 lug?
Post by: Camfirchev on March 11, 2010, 10:59:08 pm
They did make a 10 bolt with 8 lug hubs but it will be a little tough to find.  FYI Dana 44 outers will bolt right on to the 10 bolt axle, "Knuckle, Backing Plate, Spindle and 8 lug Hub Assm."  Everything will bolt right on... You can even use your existing brake calipers.   All will interchange.. Chvrolet, Ford, Dodge and Jeep.    Check out this website.
http://www.boyceequipment.com/
Post by: Blazin on March 11, 2010, 11:01:37 pm
The 10 front axles are all the same 6 or 8 lug. Its the spindle and everything that goes on it that are different.
Post by: frickenbored on March 12, 2010, 10:03:20 pm
alright so I did some more searching on craigslist and I found what I think is a very good deal.  A guy not to far away from me is selling a dana 44 front axle and a 14 bolt full floater rear axle both with 4.10 gears, both from an 86 chevy pickup, and both for $250.  I'm about to jump on this deal but I was wondering, is the dana 44 a direct bolt in for a 10 bolt front? And is a dana 44 any stonger than a 10 bolt? Also I'm not sure if its manual locking hubs or not but how hard is it to convert it to manual locking hubs?
Post by: Chevalade on March 13, 2010, 01:42:04 am
Thats a decent price, I'd snag that up. And the 44 should be manual hubs. It is a direct bolt in. Pretty sure u-joint is same as well. You may wanna run a lil bigger tire so you ain't doin 3k rpm down the highway.
Post by: Irish_Alley on March 13, 2010, 01:51:29 am
direct bolt in- yes. hubs you can even swap them out with the ten bolt, they are about the same in strength. 250 is a good price. i have 38s on my truck with 410 ratio and I'm ruining about 1800 at 50mph if i can remember right I'm running @ 60 mph it about 2200
Post by: frickenbored on March 13, 2010, 05:57:02 am
Oh I plan on running a 4" lift with 35" tires by the end of this summer, so I'm going to call this guy either today or tomorrow and hopefully grab those axles.  The 44 sounds pretty good, the add says its a HD dana 44 with a dual steering stabilizer setup.
Post by: frickenbored on March 13, 2010, 05:40:34 pm
well looks like i'm going to pick up those axles tomrrow.  and as an added bonus the guy also has a set of 8 lug aluminum hummer rims that work with those axles that have 36" goodyear mt/r's mounted on them for $50 a piece.  I'm also gonna grab those.  I think a 383, built th400, 14 bolt ff, dana 44, 4.10 gears and 36" tires are going to work very well together.  Does anyone know if a 4" lift will clear 36" tires or am I going to have to go with the 6" lift?
Post by: fitz on March 13, 2010, 06:14:57 pm
 Not to rain on your parade but I didn't think they made a Dana 44 in 1986.
 And as far as the 8 lug Hummer rims, are they factory? I know allot of guys run the factory hummer steel wheels with the 37" tires on our trucks but they have to recenter the rims to make them fit.
Post by: frickenbored on March 13, 2010, 07:35:47 pm
The dana 44 may not be the orignal axle but I'm figuring that if it was already mounted on a 1986 pickup then it should bolt right in since the front ends are the same.  As for the hummer rims they were the rims that were on these two axles already.
Post by: frickenbored on March 14, 2010, 07:30:36 pm
I picked up the axles today and they are in perfect shape and according to all my measurements they are direct bolt in's.  I have a question about the gears though.  I counted the ring and pinion teeth on both the dana 44 and the 14 bolt ff.  The dana came up with 45 teeth on the ring gear and 11 teeth on the pinion gear which comes out to 4.090909090 or 4.10.  Now the 14 bolt came up with 42 teeth on the ring gear and 11 teeth on the pinion gear which comes out to 3.81818181 or 3.82.  I've searched everywhere and 3.82 is not even an option for any GM axle and this is def a GM axle.  I'm not sure what to make of this...
As for the tires their like new Goodyear wrangler RT II's 36x12.50 R16.5  The hummer rims havent been recentered but for 50 bucks a piece I still bought them and I'm just going to get a cheap set of steel rims.
Post by: frickenbored on March 14, 2010, 09:29:07 pm
I just bought a 14 bolt ff for my 1988 K5 blazer and I was wondering how to tell if its equipped with a gov lock.  When I turn one tire the other spins in the opposite direction like an open diff but from what I understand the gov lock doesn't kick in untill theres a load on it.  I'm hoping its an open diff that way I don't have to replace the carrier to install a detroit locker.  $350 compared to $770
Title: Re: 14 Bolt Full Floater
Post by: Da67goatman on March 14, 2010, 09:39:13 pm
The best way is to pull the cover and look for clutches vs spider gears.  But if you don't want to open it, keep one the yoke from turning and spin a wheel.  If it doesn't want to spin, its gov lok, if it spins its open carrier.  At least this is what i was told.  I haven't pulled the cover on mine to find out how accurate it is.
Post by: frickenbored on March 14, 2010, 09:59:08 pm
I already pulled the cover today to count the teeth on the ring and pinion to make sure they were 4.10.  I dont think I saw any clutches but would I have to open up the actual carrier?
Post by: Blazin on March 14, 2010, 10:45:51 pm
A gov lock has all kinds of crap, shafts, cams, springs etc. they are right there when you pull the cover.
Post by: Irish_Alley on March 15, 2010, 06:18:46 am
the only thing is can think of is you miss counted and there are 41 teeth on the ring and 11 on the pinion that means its 3.73. if you look at the ring there will be some numbers post them
Post by: frickenbored on March 15, 2010, 11:38:47 am
I did miscount...it was hard to count the pinion teeth from the top of the diff so today I unbolted the pinion shaft assembly and pulled the shaft out and counted 10 teeth so it is in fact 4.10.
Post by: fitz on March 15, 2010, 11:49:09 am
Pull the cover and look for broken parts. If you find any, you have a gov loc.
Post by: SUX2BU99 on March 15, 2010, 12:16:54 pm
^ lol
Guts of an open diff:
(http://memimage.cardomain.com/member_images/1/web/3001000-3001999/3001366_42.jpg)
Guts of a Gov-lok:
(http://memimage.cardomain.com/member_images/1/web/3001000-3001999/3001366_40.jpg)
Post by: 1984k30 on March 15, 2010, 01:53:11 pm
A 14 bolt is a little harder to tell as compared to a 12 or 10 bolt. You have to look in the little hole of the carrier.  The one with the arrow has a detroit locker you can see part of the spring.  The other is a open spider assembly
Post by: frickenbored on March 15, 2010, 03:43:52 pm
Heres a pic of the new axles, their in pretty good shape...
(http://img682.imageshack.us/img682/3112/axles.jpg) (http://img682.imageshack.us/i/axles.jpg/)
They dont need much the dana 44 just needs the manual locking hubs from my 10 bolt since one of the hubs on the 44 is broke.  Other than that its perfect, i'm just gonna replace the ball joints, tie rods calipers, brake lines, u joints, steering stablizers and get the rotors re-surfaced at the shop I work at.  The 14 bolt only need a new cover since the bottom of the cover has excessive rust, brake lines and a brake drum overhaul kit.  The left side brake is stuck on so the drum wont move, that should be fun getting that drum off.
Post by: frickenbored on March 15, 2010, 03:46:53 pm
I'm pretty sure its an open diff, Heres some pics:
(http://img693.imageshack.us/img693/5837/14boltff.jpg)
(http://img138.imageshack.us/img138/4413/14bolt.jpg)
