73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: treestandjunkie on March 14, 2010, 04:38:35 pm
Title: Score!!
Post by: treestandjunkie on March 14, 2010, 04:38:35 pm
I just picked up an 89 4x4 suburban for $400. I was just calling about the front clip to put on my 87 truck. Now I wonder what all parts will interchange??? Front/rear ends? Steering column. dash and guages. calipers and rotors. etc. The main thing i am wondering about is the front and rearends. here is a pic of the burb. The parts will be going on the truck that is my profile pic. Thanks for your help.
Title: Re: Score!!
Post by: VileZambonie on March 14, 2010, 04:58:47 pm
pretty much the front doors forward and nearly everything mechanically will swap. Good score!
Title: Re: Score!!
Post by: Lt.Del on March 14, 2010, 10:53:43 pm
Quote
Check the RPO's--should find them in the glove box.  you should be able to tell the  axles, etc..
http://www.c2e.info/rpocodes/
Title: Re: Score!!
Post by: treestandjunkie on April 02, 2010, 11:22:27 pm
Finally I went and picked up my suburban I plan on using the rearend (after I determine what ratio), front core support etc. for the headlight swap, tilt steering collumn, Windsheild, and guage cluster. Not much else I can use.
Title: Re: Score!!
Post by: VileZambonie on April 03, 2010, 06:03:20 am
You'd be surprised. Strip it good and save evrything in containers you can. The TBI system alone is a good score. What about the engine and drivetrain?
Title: Re: Score!!
Post by: treestandjunkie on April 03, 2010, 10:08:11 am
It didnt come with engine and tranny but it does still have the 241-c transfer case. I know nothing about these. Good , bad , ok ????? I dont know. And what are they worth used??
