73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Tazman on March 15, 2010, 12:04:00 pm
My 87 is stock with fuel injection.Once in a while when at idle it will fluctuate a little,enough that the oil gage moves.Any ideas on what this is and how it can be fixed?Thanks
is it when it first starts up cold, or after driving a bit w/ a warm engine?
Check for vacuum leaks and check the tbi base gasket
Any codes? You could check your idle air control valve. Any other symptoms?
Also does the volts drop any ?
It does it when warmed up mostly.Thanks for the ideas I will check those out.
The reason I asked about the volt is when my 94s alt was going up it would stop charging and the truck would run off the battery causing it to idle erratically
I will check that,I do not have an alt gage.Thanks
