73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: three8six on March 15, 2010, 11:20:00 pm
Title: Transmission Leak
Post by: three8six on March 15, 2010, 11:20:00 pm
I have a transmission that leaks from the between the engine the and trans and was wondering what could be done to resolve this?
Title: Re: Transmission Leak
Post by: VileZambonie on March 16, 2010, 06:47:40 am
Remove the trans and check the converter neck. Check the pump bushing and replace if necessary. Replace the converter seal. Check the pump seal around the circumference of the pump too. If it's leaking drop the pan and remove the filter & TCC solenoid. Remove the pump and replace the gasket and seal.
Post by: three8six on March 16, 2010, 12:16:32 pm
thanks
