73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: BIG CHEVY on March 27, 2010, 04:35:22 pm
EXACTLY WHAT KIND OF LUBE DO YOU PUT IN THE REAR CHUNK OF MY TRUCK? ALSO DO BOTH TAKE THE SAME THING?
I HAVE A 79 K-10 WITH NP 203. NEW TO ME SO I AM GONNA MAKE SURE ITS DONE RIGHT SO FOR PEACE OF MIND
I WANT TO BE IN AGREEANCE WITH ALL OF YOU. THANKS GUYS.
Do you mean the read end? 80w90
YES BOTH REAR AND FRONT. ALSO THE FRONT HAS A DRAIN PLUG AND A HOSE COMING OUT OF THE TOP.
THE REAR HAS NO PLUG AND THE SAME HOSE COMING OUT THE TOP. WHAT GOES IN EM? AND WHAT ARE THOSE HOSES?
HOW DO I CHECK THE REAR OR ADD/REPLACE?
Those are both 80w90. If it's a posi in the rear you'll need limited slip additive. The hoses on top are breathers and they just vent the housings. Just remove the fill/check plug on level ground. the level should be just about to the bottom of the fill plug. The fill/check plug on the rear is not on the cover, it's on the front side and is a 3/8" drive square so just use a 3/8" ratchet to remove it. Make sure you clean around the check plug before you remove it.
You can drain them and replace with synthetic oil.
By the way all caps. is considered yelling!
