73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: treestandjunkie on April 03, 2010, 10:51:56 pm
Title: np 241-c
Post by: treestandjunkie on April 03, 2010, 10:51:56 pm
I found out today that the transfer case that came with my 89 suburban parts truck that I bought is a NP 241-c transfer case. Are these good. I know nothing about them. And how much would one be worth in used condition? Thanks.
Title: Re: np 241-c
Post by: Chevalade on April 03, 2010, 11:56:58 pm
In theory, the 205 is stronger, but I've heard very little of NP241's breaking. The 241 was designed for Heavy duty 1-ton applications, so it's designed to take internal stress like the 205 is. Chances are, you won't be overloading a NP241.
Price is a relative term depending on location/need. Keep it, you may need it some day.
Title: Re: np 241-c
Post by: VileZambonie on April 04, 2010, 09:54:52 am
The 241 replaced the 208
Title: Re: np 241-c
Post by: treestandjunkie on April 04, 2010, 06:01:41 pm
I thought about putting it on ebay or craigslist. What would one of these be worth??
Title: Re: np 241-c
Post by: Chevalade on April 04, 2010, 07:26:28 pm
Just a quick look around the net says $175 to sell fairly quick to $300 if you want to sit on it. (also depends on condition)
Title: Re: np 241-c
Post by: VileZambonie on April 04, 2010, 08:36:47 pm
$75-$125 bucks around here.
Title: Re: np 241-c
Post by: fitz on April 07, 2010, 06:54:42 pm
I've got a pile of them and I cant seem to get $50 ea for them. From what I understand the 241 is basically a 208 with a better oiling system inside (A 241 will bolt in place of a 208).  The 91 241 ran an electronic speedo which may be helpfull to some people.
Title: Re: np 241-c
Post by: VileZambonie on April 07, 2010, 09:08:38 pm
I put a 241 in my mutt project and fitz is correct on the oiling. The reduction ratio is lower too.
Title: Re: np 241-c
Post by: treestandjunkie on April 07, 2010, 09:25:17 pm
Thanks guys!!
Title: Re: np 241-c
Post by: Captkaos on April 07, 2010, 09:27:28 pm
This will go on the 4L60E you just posted about.
Title: Re: np 241-c
Post by: highsierra86 on April 08, 2010, 08:55:07 am
I have a 241C inMt 86 I can't find a adapter to convert the electric signal to the mechanical speedometer any help?
Title: Re: np 241-c
Post by: fitz on April 08, 2010, 05:49:48 pm
It may be easier to just install a 241 from an 89-90 Blazer/Suburban that runs the cable driven speedo. It sounds like you have a 241 from a 91 Blazer/Suburban.
Title: Re: np 241-c
Post by: Tater502 on April 08, 2010, 11:11:29 pm
I just put a 241C out of a 91 blazer in my 79 gmc. The gauge cluster out of a 91 suburban(same looking gauges as your truck) will be going in as soon as I figure out the speedometer wiring. Im hoping the 2 wires coming out of the transfer case will go straight to the vss? box on the back of the cluster.
Title: Re: np 241-c
Post by: highsierra86 on April 13, 2010, 06:14:46 pm
I figured it was out of a blazer/burb but the output for the front diff is on the passengers side all the other ones I seen are reverse but thanks didn't know any 241s were setup for cable drive speedometer
Title: Re: np 241-c
Post by: fitz on April 13, 2010, 11:21:40 pm
89-91 Blazers and Burbs ran the 241 with the front shaft on the pass sides.
