73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: DirtyShawn on April 13, 2010, 03:20:06 am
ok my th400 is not working right..i have first gear and rev's only.if i put it in 2nd or 3rd it locks the tran's and will not move. locks up wheels if you moving and shift to 2nd or 3rd gears. were and what part am i looking for to fix?
Sounds like it needs a rebuild.
well thats a given.. i just wanted to know if it could be in the valve body for the gears
How about a little information on the history and if anything has been done to the trans?
It almost sound like it has a trans brake
reverse must be applying when in drive or 2
Get it to a tranny shop before you kill it completly
it has a built tranny from a ump race car
rev's valve body manual.
im going to drop the pan today and take photos
but i was driving and sifted from 1 gear to 2 and bam it locked up. dropped back to first it drove home fine
Sounds like a valve body issue.
im hopping.
Like a bunny?
lol i didnt see how i spelled it lol lmao.
hoping
ok i think i got it. this is what i have in my trans.
HP2211R – TH400 Full Manual
Reverse Pattern Valve Body
so could it just have a valve stuck and needs cleaned out ?
Sure or loose valve body bolts, gaskets etc
ok this is what i did to day. pulled pan and dumped out fluid
it was a bright red so thats good right?
pulled the valve body off. i think some parts are gone!
no govoner tubes with from what iv see is what is removed with the valve body has been
changed to a kit i posted above.
there was 1 check ball and a lil spring.
here are some photos too.
now with the valve body off i can role the truck when in 2nd and 3rd gear
it was locked up what did i undo and can i just put it back on after cleaning the valve body?
im so lost here but im learning .. so whos got any info.. has the trans been built for racing?
so one last run down of what i have
th400 manual valve body & a np205
(http://i156.photobucket.com/albums/t39/dirtyshawn/PICT0004.jpg)
(http://i156.photobucket.com/albums/t39/dirtyshawn/PICT0005.jpg)
(http://i156.photobucket.com/albums/t39/dirtyshawn/PICT0011.jpg)
(http://i156.photobucket.com/albums/t39/dirtyshawn/PICT0012.jpg)
Why don't you set it up back to normal? Get a new seperator plate and vb gaskets. Get a trans go reprogramming kit and set it up the way you want. Why do you need a manual valve body for your set up?
http://www.transgo.com/rpg_generalmtr.php
Thats just it i dont need it. its just what was in the the truck
i got this truck not knowing some one had done all this to it the guy got it
this way too. he didnt know. so do we just had a bad axx tranny or a crappy one some one made work
ok i just looked at the kit you showed me . not bad and easy to do too.
but what im trying to find is why it locked up in 2nd and 3rd gear before i buy any thing but now that i have
pulled the valve body my truck will roll in 2nd and 3rd gear.. im hoping the valve body was just stuck.
but when i pulled the valve body i found i missing some parts and dont no why.
i only have 1 check ball and a spring.
the 2 tubes off the valve body are gone.
modulator valve has been removed and a red plug is filling the hole.
there is no acumulator servo at all in the valve body.
i posted a photo showing every thing that came out of the valve body.
this is every thing that came out..
i hope too clean it all and reinstall it and it work as is.
but i didnt look where the ball and spring were so now im looking for that too.
any one know what and why this trans has been done this way?
and why it locked up in 2nd & 3rd but came free when i removed the valve body?
i'm so not a tranny guy but i did have 1st and rev before
i removed it it would just lock up if i shifted or tryed to move in 2nd or 3rd
Put it back to stock and get a new seperator plate. Then install the trans-go vb kit. Don'y mix up the two gaskets which people often do and you should be good to go.
dont have the cash for that yet. but im not doing any thing till i know if the trans is trashed now from locking up..
found a stock on close to me. may do that. i still want to know why and what they did to this thing.
and why there are parts gone. if its a race trans it should be worth something.
cleaned the valve boy and got a lot of black stuff out of it? whats this stuff fluid was bright red.
A separator plate and gaskets will cost you about $35 bucks.
just got layed off dont even have that.
if i have to i may just sell it and start over,
just to much work done i dont under stand on this truck
still say why a 4 link on a 4x4
Having a modified vehicle means #1 working on it constantly and #2 money. You might be better off selling it if $ is too tight and it's not what you want.
ya i was thinking that.i clean the valve body and im going to reinstall it and see. but i found a stock th400 here for $150
