73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: tkleinia on April 15, 2010, 08:54:27 pm
Title: Slightly dissappointed
Post by: tkleinia on April 15, 2010, 08:54:27 pm
86 K10 Originally V6 700r4 3.43  NOW 383 TH350 3.43
Sorry for the long post...
Long story short: I swapped out a tired 350 for a home built (I built it) 383 stroker... I took it for a spin... and am slightly dissappointed. While its better than the old engine, a Metro will beat it off the line. :-\ I now am deciding what to do next.
I have some ideas of what I can do to the engine... It has an extreme 4x4 cam now, could swap that...
I purchased all the parts to end up with a compression ratio of 9.5, to do so, I had to install dished pistons, but may have gotton carried away cleaning the casting of the cumbustion chamber, lowering the ratio(thought I was helping, I now realize I may have hurt performace since I did not compensate for the loss of squeeze), ... could install flat tops and should be safe.
But my other thought, and my reason for posting... is my trans, gearing, and tire size killing me?
I have a 350 trans, 3.43 rear gears, and 33 in tires.
I am considering swapping in a 700r4. Which is what the rear end was set up for from the factory. I would imagine I will benefit from the 700's shorter first gear. I may swap out front and rear gears in the future.
Any thoughts? Is my drivetrain combo killing me?
Title: Re: Slightly dissappointed
Post by: VileZambonie on April 15, 2010, 10:03:25 pm
What exactly did you do to the heads? What heads are you running? Why did you get rid of the 700R4 in the first place?
Post by: tkleinia on April 15, 2010, 10:12:48 pm
64cc  Iron Vortec heads
I smoothed the casting "profile" from the chambers and intake runners, and polished the exhaust runners. No reshaping. Stock valves and springs.
Previous owner installed the first V8 and th350. The glove box tag reads v6 with overdrive trans and 3.43 gears (gears verified)
Post by: Gregzz4 on April 15, 2010, 10:15:44 pm
You did not mention fuel delivery
That stroker will want some airflow from a decent carb
What carb and fuel are you using?
I have a stock Q-jet with something like 750-795 CFM and my ZZ4 loves it.
I ran it for years on 92 Octane, but with the new 'up to 10% Ethanol @ Chevron', I now run it on 94 Octane and am really surprised that the stock coil will light the extra Octane. I have a noticable difference in throttle responce.
Post by: tkleinia on April 15, 2010, 10:19:40 pm
600 Edelbrock (is that too small?)
89 octane.
I use it for towing a boat during the summer. The idea was to not go broke on paying for high octane fuel with the power benifits of a stroker...
Post by: VileZambonie on April 15, 2010, 10:23:48 pm
IT should have some pep based on what you've told us. HEI Ignition? Is it timed correctly? Cam timing is correct?
Post by: Gregzz4 on April 15, 2010, 10:33:30 pm
Besides the fact that my truck was labeled '91 Octane' from the factory ( Towing/Hauling ? ),
I have always run 92 Octane.
Then when I put in my Crate ZZ4 it needed 92.
So, when I installed the motor, I was talked into a Holley Avenger 670CFM as GM claimed they got their ratings for this motor with a 600CFM, like you have.
I drove it over half an hour from the city, on the highway, to a tuner buddy. I went there because I was Very disappointed with the HP change. He had to Under Jet the Holley so much that he told me either the Carb is junk, or it needs to be bigger.
I raced back home in a hurry because he was closing soon, put on the stock Q-jet, burned rubber all over my neighbourhood, beat the Devil on the highway, and then he changed the rods and jets to Bigger/more fuel ones to make it even better.
When GM says 600CFM, I say BS.
And I only have 58cc Heads.
I'd be willing to guarantee you that you need a Much bigger carb and burn a little better than 89. But you could experiment with that.
Your Spark system will need to handle the higher Octane, as will your Compression Ratio. Mine is 10:1 or so.
Other thing you could do is supercharge it as your Compression is almost low enough  ;D
Post by: tkleinia on April 15, 2010, 10:35:42 pm
New HEI distributor with MSD internals. adjustable vacuum advance
(everything, i mean everything is new with the engine minus the bored 4bolt block)
The short block was put together by a reputable shop and the cam was degreed. (supposedly, starting to wonder)
The timing is set correctly with input from the cam card (don't remember exact figures, engine was built last summer, and have only driven it 500 miles since. (sat over the winter)
Post by: eventhorizon66 on April 15, 2010, 10:36:22 pm
A few thoughts:
What is your ignition timing?  Get that wrong and you could turn a 572 into a turd.
Did you use a carbide cutter or an emery roll to clean the combustion chamber?  Are you sure you didn't knick a few valve seats?  Did you do a quick check lap with some fine lapping paste?  Have you performed a compression test?
Is your mixture too lean?  Wideband A/F monitors are getting cheaper all the time.  WOT should be 12.8:1-13:1.  Does it do anything in particular or are we talking a general lack of power?  Are you getting adequate fuel volume to the carb (good fuel pump, no kinks in the fuel line, etc.)
Post by: tkleinia on April 15, 2010, 10:39:50 pm
lol Thats not the first time ive heard that!
Post by: Gregzz4 on April 15, 2010, 10:40:58 pm
So what's your initial and WOT timing?
Post by: tkleinia on April 15, 2010, 10:45:58 pm
A few thoughts:
I will definatly check the timing again. If I rembember right I quit trying with it timed at 30 degrees...
I used emery rolls, no carbides. Yes I did a quick lap as the Vortecs already had a three angle.
No idea on a mixture...
Post by: tkleinia on April 15, 2010, 10:48:41 pm
I am not a mechnic, just a wrench.
I dont beleive I have the cam info any more... Does anyone have a suggestion of what kind of timing may work for me?
Post by: Gregzz4 on April 15, 2010, 10:50:43 pm
As to your first question, no, your gears, tranny and tires are not holding you back from burning rubber
Although you might break some stuff if you push it enough
The TH350 can handle all this IF it was built well enough.....mine survived 20+K with a 12Bolt one tire fire and stock rubber...that's with 355HP and 405FT pounds...then I blew it up 'cause I didn't service it. Blew some U-joints though.
The tires you have will put some stress on the drivetrain, but your Stroker should give you enough power to break them loose, even with Posi.
Post by: eventhorizon66 on April 15, 2010, 10:55:15 pm
If it were me, I'd probably start with around 8 degrees initial and 28 total, then add timing until the engine response doesn't improve anymore.  I'd think you should end up with around 10-12 initial and 32-34 total.
Post by: Gregzz4 on April 15, 2010, 10:57:43 pm
I would think your initial timing should be @ about 10 Degrees, but double-check that with someone
You may benefit from a little higher initial timing ( mine's @ 11 but I could get 12 maybe after I fatten up my primary circuit in my carb ), but you'll need to listen for knock under mild load, like uphill, so you don't get detonation
I can't push my timing up too much because of my Compression.....you may be able to go higher with your setup. Just don't let it Ping
Total timing may be OK up to 36 Degrees, depending on your parts and the Octane
Mine is OK @ 36 due to my Octane....no knocks/pings
Most pump fuel racers don't go above 36
Post by: tkleinia on April 15, 2010, 10:59:33 pm
It has a brand new trutrac in the rear, and will burn the 33 12.50s into 2nd gear... evertyhing holds up...
My issue is from a standing start, and lack of power up hills.
If I floor my 94 (150k mile)chevy going up a hill, it climbs right up to 80mph (or however fast you like)
But my 5,000 dollar(engine cost alone) 383 fights to hold 60mph
Post by: Gregzz4 on April 15, 2010, 11:06:08 pm
So, as we said, check your timings
If that doesn't help much, try a bigger carb
I love my Q-jet
Emissions are a breeze and Camaros are fun to surprise
Post by: eventhorizon66 on April 15, 2010, 11:06:53 pm
If I dropped 5K on an engine, I'd definitely invest in something like this:
http://cgi.ebay.com/ebaymotors/Innovate-Wideband-o2-Sensor-LC1-DB-Gauge-Kit-LC-1-G5_W0QQcmdZViewItemQQhashZitem483a19c697QQitemZ310212413079QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Post by: tkleinia on April 15, 2010, 11:11:14 pm
Thanks everyone
I will re-check my timing and see how that works.
I will also look into the a/f gauge!
I still wouldnt mind the highway gear...
Post by: Gregzz4 on April 15, 2010, 11:28:54 pm
What do you mean by highway gear? You don't want to kill that great stroker with bad gears !!!!!!!!
Your 3:42 is perfect for city/street performance driving
What you need is to put a 700R4 back in there
I run factory tires and I am @ about 16-1700 RPM @ 80 MPH on a flat, whereas my old TH350 was giving me almost 3200 RPM !!!!!!
Just some more info to think about/spend money on
Get a 700 built to handle the power/torque and you'll never look back
Just make sure you research the carb connections for the TV cable and get the wiring for the lockup
Go here
http://www.bowtieoverdrives.com/index.shtml
PS: you can always PM me if you want info about installing a 700R4 where one was not before as I and a buddy have gone through many headaches with this conversion
Post by: Donut on April 16, 2010, 03:50:51 am
Timing, everybody has put you in the ballpark.
Cam specs would be helpful, especially since Vortecs are lift limited and you did say you still have the stock springs installed.  (ie. no "beehives", no mention of any head work to increase lift capacity)  Even my little Summit 1103 cam didn't have the lift clearance.
