73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: chronos on May 04, 2010, 07:14:05 pm
Title: pressing in lower ball joints
Post by: chronos on May 04, 2010, 07:14:05 pm
I am putting in my new lower ball joints.
How far do you have to press them in?
I can still see about a 1/16" of the 'knurles' part of the BJ
from underneath. I am REALLY tightning the ball joint press tool with a big 4 foot breaker bar!
It does not want to go in that extra bit.
Any help PLEASE
Title: Re: pressing in lower ball joints
Post by: bgctrading on May 04, 2010, 09:32:59 pm
I usually use a BJ press (c clamp style) and tight them with an impact wrench and if they are a little bit stuck I tap the straight part of the C clamp with a hammer and that usually jars them on in. If you dont have an air wrench put some good pressure on it with your breaker bar and tap it the same way.
Post by: chronos on May 04, 2010, 10:18:47 pm
I will try that BUT I am really reffing on that big breaker bar!
They are still not fully in(I don't think?) and I can't barely move the breaker bar at all.
I don't want to damage the new joint but want to make sure it is seated right
Post by: Irish_Alley on May 05, 2010, 03:50:45 am
It should seat up to the ridge of the joint I never used a ball joint press I’ve just used a hammer and brass rod to smack them in place
Post by: chronos on May 05, 2010, 08:42:36 am
I will be trying again tonite.
Looking at SGTDel's writeup again,I see when pressing BJ in he has the press tool the
opposite way I did (tightning press from bottem of control arm)
Not sure if that matters but I will try it that way
Post by: chronos on May 05, 2010, 06:53:02 pm
Ok got both BJ pressed in. Drivers side is Good
but passenger side has play in the Ball joint >:(
It rocks a little in the hole....why????
How do I fix this problem now,can I tack weld it in
or is that a stupid idea??
I DO NOT want to replace the control arm if possible
Advice from the experts please :)
Post by: bgctrading on May 05, 2010, 07:54:32 pm
Do you have a pic or can you tell me the year make and model of your truck. I have seen some screw in type BJs in chrysler vans that the control arms get wore out and you can tack weld them in but if you had to press it in I imagine something is wrong.
Post by: chronos on May 05, 2010, 08:09:36 pm
I will take a pic and post.
Its a 86 2WD. there is play in the hole for the BJ
Its a TRW BJ
Hoping it can be tack welded
Anyone ever had to do this? I double checked and it is the right BJ
Hoping for some feedback....thanks
Post by: chronos on May 06, 2010, 08:15:35 am
Well I now know why my lower BJ rocks a little in the hole !
It seems buddy was cleaning up the lower control arm for painting and may have got
too happy cleaning out that hole !
Oh well , now I have to fix things up.
I have done some research on tack welding the lower BJ in and it SEEMS like it
could be the answer.
Have any of you done this type of thing on our trucks??
Help please  :)
Post by: 80stepsideguy on May 06, 2010, 10:53:09 am
I wouldnt reccomend tack welding in any suspension parts.The welds would break and you be stranded .Plus then the control arm would be junk.Cause you will never get that ball joint out to replace it.If i was you i would go get another 1 from the salvage yard and make your BUDDY pay for it since he did screw it up .
thanks
pat
Post by: chronos on May 06, 2010, 02:27:41 pm
Going to get The lower BJ tacked in three spots from the underside / bottem
Can't believe no one has had this problem on here?
Talked to several people and searched the net extensively. Spot welding lower BJ's
seems like a common practice and is factory done on several models with press-in BJ's
After all the work I've done there is no way I'm swapping out the control arm
at this time
Post by: VileZambonie on May 06, 2010, 02:52:58 pm
What factory ball joints are tack welded in place?
Post by: chronos on May 06, 2010, 03:04:37 pm
Mid 90's RAM's are one that I know of
from searching this out
I can't see how this will be a problem.
If you think it will be PLEASE tell me why before I get it done...lol
Seems like tacking them in would be safe and stong to me
Post by: Irish_Alley on May 06, 2010, 03:09:34 pm
I ain't seen them spot welded cause they have to be replaced and well welds tend to leave nasty marks behind, now iv seen then riveted on another style. Didn't someone else have a problem like this but it was due to a factory mistake from the ball joint maker over sea I think one was made in taiwan and the other was china or something
Post by: chronos on May 06, 2010, 03:14:51 pm
The ones spot welded from factory make you replace the
entire control arm. There are several factory spot welded in BJ's,mostly cars,but some pickups.
The BJ's I got are TRW lifetime. Trust me I have been doing alot of searching on this
and want to be safe first and foremost.
Post by: VileZambonie on May 06, 2010, 03:18:20 pm
If you want to be safe first and foremost then do it right. If the ball joint is floating around in the control arm you need to replace the control arm.
An integral ball joint does require the control arm be replaced. Still there are no tack welded ball joints that I've ever seen or heard of.
Post by: Irish_Alley on May 06, 2010, 03:21:31 pm
Save I can see but if its not stock doesn't make it safer. I would try to figure out what's wrong with the ball joint like it is
Post by: chronos on May 06, 2010, 03:53:08 pm
Well , gonna look into my options on control arm.
Going to try a different BJ first off since they are lifetime
and go from there
There are factory press-in BJ's that are also tack welded from
the factory , been googling this all day.
Not looking forward to this as I was close to the end...lol
Post by: VileZambonie on May 06, 2010, 11:34:43 pm
Quote
Again, never seen it so please give us a specific example of factory tack welded in ball joints.
Just buy a used control am if yours is toast.
Post by: chronos on May 07, 2010, 08:52:05 am
Got my new(used) control arm. $50 from wreckers
Now to paint and get the old one out and new one in
Is there anything more to it than bolting it in?
I have new u-bolts from dealer , anything to watch out for?
If you want to google "tack welded" "lower ball joint"
there is lots of reading there
Post by: VileZambonie on May 07, 2010, 02:13:54 pm
Be careful, give yourself enough room to fit a floor jack under there and be able to get the spring out.
Post by: chronos on May 07, 2010, 02:27:50 pm
The spring is loose and spindle are already off.
Is it just a matter of getting the u-bolts off and putting on the new control arm?
Is the arm just centered and bolted on?
Thanks for all the help !
Figured I've come this far got to do it right , never taken off a control arm
so wanted to avoid that but you guys steered me right
Post by: chronos on May 07, 2010, 11:07:57 pm
Got the old arm off , really easy.Should have taken them both off
from the start !
Another coat of chassis saver on the new arm and its ready to
go in.
I see now that the control arm shaft has two holes in it to
line it up,,,,
Post by: VileZambonie on May 08, 2010, 06:08:28 pm
New bushings are a good idea while it's out. I painted mine with rustoleum hammered finish and they look cool
Post by: eventhorizon66 on May 09, 2010, 12:22:14 pm
I guess it's a little late to mention this, but AC Delco #45D2022 ball joint is listed as an "oversize" ball joint.  I would think that this would do the trick, if the ball joint hole is still round but just a tad too big.
