73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: 78 Chevyrado on May 24, 2010, 05:35:47 pm
Title: U bolts
Post by: 78 Chevyrado on May 24, 2010, 05:35:47 pm
I'm going to need new U-bolts for my rear leaf springs.   The inside measurement (width)  of mine are 3-3/8"  All I can find on the internet is a 3-1/2" width.  Can I use these?   the stockers are 3-3/8"  and the u-bolts that came with the lift kit are also 3-3/8"    I need some custom length u-bolts because I have lift blocks and the u-bolts I have now are just a tad shorter than I'd like them to be.
I don't think it would be good to use the 3-1/2" ubolts...  that doesn't sound right, but I cannot find 3-3/8" anywhere...   anybody have any links?
Thanks guys
Title: Re: U bolts
Post by: beastie_3 on May 24, 2010, 05:43:42 pm
Check around local shops, they can custom make them on the spot.
Title: Re: U bolts
Post by: heavychevy91 on May 24, 2010, 05:45:55 pm
x2 just bring the plate in and the length you need. usually theyre better quality than cheapo parts store ones
Title: Re: U bolts
Post by: 78 Chevyrado on May 24, 2010, 06:38:04 pm
I'd like to, but for some reason specialty shops are all like 30 miles away from my house, and for the time being im grandads full time caregiver, so I don't get but a couple of hours off each week, it's a 24/7 deal right now.   That's a big reason I'm gonna buy a short block for my engine instead of doing the whole machine shop thing on my old one....   I'm stuck here for a while so the Internets kinda my only link to the outside.   I can work on the truck when hes on the porch, but i cant go anywhere as he cant....
Title: Re: U bolts
Post by: Wardog on May 29, 2010, 11:38:56 pm
I get mine from NAPA.  Provide them with dimensions or the original and they can usually have em there in a couple hours.
Title: Re: U bolts
Post by: Irish_Alley on May 29, 2010, 11:53:47 pm
i my u bolts that came with the lift kit were too big also but with a little bit of squeezing i got them to fit they were about 1/2" too wide for the spring plate haven't had any problems took them off a couple times since then and no signs of wear
Title: Re: U bolts
Post by: Mtrhd329 on July 12, 2010, 11:06:09 am
x2 on the local shops.  I had some made while i bs'ed with the guy about a desert car he was building in about 10 minutes and only set me back about $50.  Of course i was putting in a 14 bolt which have larger bolts.  Most auto parts stores have the cheapo lift kit u bolts that fit the 12 bolt but they look pretty flimsy to me.
