73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: Armor on June 05, 2010, 10:08:03 pm
Title: Recently fell in love...
Post by: Armor on June 05, 2010, 10:08:03 pm
I saw a 79 today with the newer truck rims on it, from 07+
(http://www.revo1.com/misc/silverado20wheels.jpg)
the problem is Blue is a 1/2 ton with 5 bolt rims
is there a way t get these newer 6 bolt rims to work, with either wheel adapters or something, are these even safe?(i dont do anything drastic with the truck, ocasional light towing)
http://adaptitusa.com/5x500to6x550wheeladapter.aspx
or would i have to try and change the rear axle and the front somehow?
i dunno if its possible, but with the pics ive found on here also with the rims its nice.
or, does anyone know of a compnay that makes them aftermarket to that same look, geting 5 bolt ones would be amazingly simple....
any thoughts would be great
morgan
Title: Re: Recently fell in love...
Post by: Irish_Alley on June 05, 2010, 11:23:46 pm
(http://i11.ebayimg.com/04/i/000/90/98/d906_2.JPG)
now this is a little high but it works
http://cgi.ebay.com/ebaymotors/5-6-lug-Lug-Conversion-Wheel-Adapters-1-8-Thick-_W0QQcmdZViewItemQQhashZitem53d9061799QQitemZ360123340697QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/5-LUG-6-LUG-ADAPTER-KIT-5x4-5-4-75-TO-6x5-5-_W0QQcmdZViewItemQQhashZitem439f4e20c9QQitemZ290435506377QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
whats our size? isnt it 5x4.5
Post by: VileZambonie on June 06, 2010, 08:08:29 am
2wd is 5x5 bolt circle. And there is nothing wrong with using adapters as long as they are installed correctly.
Post by: Armor on June 06, 2010, 01:26:50 pm
so with proper(not 30$ cheapies) adapters like the ones i linked, done to proper torque and such, would not be too rough on balljoints and the like?
 also would the stock backspacing and all be fine to use if the new mating surface is 2in farther out with those installed?
thanks again
morgan
Post by: VileZambonie on June 06, 2010, 02:30:13 pm
Measure, you may want thicker spacers in the back and thinner ones in the front so you have the correct stance
