73-87 Chevy _ GMC Trucks => Performance => Topic started by: greatdane on June 18, 2010, 11:33:21 pm
Title: headman headers #69088
Post by: greatdane on June 18, 2010, 11:33:21 pm
Anyone running these headers. Do you like em? How does the coating hold up? Do the fit well? I am thinking about getting them so let me know....
Title: Re: headman headers #69088
Post by: ont_guy_38 on June 20, 2010, 06:32:17 pm
I have them and the fit is well and they seem to seal up great.Have not had them long enough to tell you how the coating holds up but never seen a set at car shows or cruise nights that look bad
Post by: greatdane on June 20, 2010, 07:31:47 pm
Do the ball and socket collectors reduce from 3" to 2 1/2"? I want to run 3" all the way out....
Post by: beastie_3 on June 20, 2010, 09:53:22 pm
Why do you want 3"? What is your engine setup?
Post by: greatdane on June 20, 2010, 11:04:36 pm
This is the set up! It is a .480 lift cam .288 duration, edelbrock air gap intake, 750 edelbrock carb....
Post by: greatdane on June 24, 2010, 01:17:53 pm
Ordered the Headmans today hope they work out........ 8)
Post by: topp on June 24, 2010, 01:21:13 pm
3" all the way back is overkill for that motor and spec.
You'd see better performance with 2 1/2" exhaust
Post by: greatdane on June 24, 2010, 01:33:55 pm
Is this the consensus because I am geting ready to order mufflers soon???
Post by: Captkaos on June 24, 2010, 03:39:38 pm
I wouldn't run 3" on there, 2.5 should be fine.
Post by: beastie_3 on June 24, 2010, 05:22:36 pm
I agree. I dont see a need for 3" unless its a modified BBC. Or you are running single exhaust.
Post by: greatdane on June 26, 2010, 08:45:21 pm
2 1/2 it is then! Im going with Hooker Area Chambers in 2 1/2" center in and center out............ still dumped at the rear axle!
Post by: greatdane on July 02, 2010, 08:24:08 pm
Headers showed up today..............there sweet looking!!!
Post by: txswb87 on July 05, 2010, 07:35:50 am
I have an 87 SWB that is TBI. I have a 383 stroker I'm ploping in and taking out the computer. I have a couple questions on the swap.
I would like to know how these fit? I have the summit headers and they didnt work, they block plugs #3&4 and also hit the starter. I guess that's the price I pay for going with the cheaper headers. ???
Post by: greatdane on July 05, 2010, 10:19:16 am
I will find out soon and let you know! My engine will be here tomorrow and I hope to have it in the truck next week sometime!
Post by: greatdane on July 07, 2010, 12:09:13 am
They seem to fit good! Plugs will be tight but OK!
Post by: Irish_Alley on July 07, 2010, 04:22:17 am
i aint never heard of that before maybe hitting the starter it crossmember but never hitting the plugs i would get a hold of summit and talk to them its not gm changed were they put the plugs at. but you do see them with dents
(http://i145.photobucket.com/albums/r210/cowgirl4christ1106_2007/ght004.jpg) to get things working right. and about hitting the starter you could always bend it
Post by: txswb87 on July 07, 2010, 10:07:23 am
I noticed in this picture that someone beat a dimple in the header for the #3 plug, I guess it is a problem however I didnt want to beat a new set of ceramic coated headers.
I have sent the headers back to summit and purchased the edelbrock shorty headers with the A.I.R. tubes which is direct replacement using my exhaust. I figured the money I save by not doing a new exhaust system is about the differance in price and less of a hassle.
Thanks for the response.
Post by: beastie_3 on July 07, 2010, 06:47:59 pm
Dane, pic didnt show up.
Post by: greatdane on July 07, 2010, 10:31:10 pm
Ya I think the pic was to big? Seeing if these work! Its close but I think there ok! Had to use a wrench to tighten it though!?
Post by: Irish_Alley on July 07, 2010, 10:43:07 pm
Even on myine #4 and 6 are a p.I.t.a.
Post by: greatdane on July 24, 2010, 05:38:56 pm
Easy install! Took me and a buddy about 45 minutes and they were on there!
