73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Harmon on July 12, 2010, 04:00:36 pm
Fixed Fuel Guage...happy
Put truck back together (new dash...replaced dash lights)
Hooked up AC with R-134-A
Blows cold, but seems to only blow in 3 positions... I thought there were 4 positions for blower with HI being the 4th one.
I replaced Hi blower relay and checked ground to cowl above blower moter----still only 3 posistions of blowing.
I checked 20 amp fuse in fuse block under dash and it is fine.
Im in Texas...I need that Hi side...any idea of what to do next?
switch is still good?
switch meaning the one in the dash?
yep.
I think thats the problem....thanks.
I have to push up really hard to the HI posistion in order for the hi side to kick on.
Thanks!
Is it possible to just by the switch and replace it for the blower levels?
Maybe. . . .http://www.autozone.com/autozone/parts/Duralast-Blower-Motor-Resistor/1977-Chevrolet-K10-1-2-ton-P-U-4WD/_/N-incirZ91tag?counter=1&itemIdentifier=239268_0_3319_5281
Maybe the switch is binding up. There are a number of wires attached to it so take note of their location. You have to remove the instrument bezel to work on it or replace it.
