73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: Lt.Del on July 24, 2010, 02:14:56 pm
Title: What's the trick to mount tires?
Post by: Lt.Del on July 24, 2010, 02:14:56 pm
I am a do-it-yourselfer.  Escpecially when it comes to brand new aluminum wheels, I don't want some 18 year old mechanic expiramenting with a heavy machine to "bend" my wheels when mounting tires to them.
So, with a little dishwashing liquid (Dawn) to lube it up, I put the tires on.  Now, the question, What is the secret to seal the tire on the wheel to inflate it?  I have 265 75 16 tires on 16x8 AR Outlaw II rims.  The size should be fine.  My air compressor is not an industrial one by any stretch of the imagination.
The tire seems too skinny but i hope it is just because I can't inflate it any to make a bead yet.
Any tricks?  Or just a more powerful compressor?
(http://www.delbridge.net/10wheel265.jpg)
Title: Re: What's the trick to mount tires?
Post by: 1HI4x4 on July 24, 2010, 03:03:31 pm
A ratchet strap around the tread of the tire should squash it enough to seal. It works for me anyhow, be sure to release the strap as soon as the tire starts taking air, or you won't be able to get it loose.
Post by: fitz on July 24, 2010, 03:07:25 pm
Nice rims.
So all you have to do is set the bead correct? My air hose from the compressor has a quick disconnect on it. I remove the valve from the valve stem, pull back the
collar on the quick connect, and stick it on the valve stem. The burst of air will set the bead. Once you hear it pop, remove the air hose, install the valve, and inflate the tire.
I'm sure this method is not OSHA approved, but it works great.
I've seen video of guys spraying starting fluid in the tire and lighting a match to it, this seems like an accident waiting to happen.
Post by: bgctrading on July 24, 2010, 03:54:23 pm
You can buy a bead seating tool "cheetah"is the brand I see most people use they are pricey but work great and are the safest method. I used the ratchet strap method for years till one day I popped an atv tire up on the beads went to release it and as I hit the lever it popped up and the gears on the ratchet left two 3 inch gouges in my wrist and a trip to the ER.
Post by: Irish_Alley on July 24, 2010, 04:55:29 pm
Andy lol its easy and I know you have all the tools
And iv done it spray a couple small squirts of starting fluid in the tire and rim hit it with a torch and the fire will expand the tire causing it to seal
Post by: 78 Chevyrado on July 24, 2010, 04:59:46 pm
Pull out the shrader core and use a rubber tip air gun to inflate it.   without the core in it the air can get into the tire much much faster, and hopefully seat the bead.  if that doesnt work, wrap a ratchet strap aroud the tread of the tire and squash it some, this will spread the sidewalls outward.
Good luck!
Post by: Irish_Alley on July 24, 2010, 05:02:36 pm
http://www.youtube.com/watch?v=zZhszvMjvjg&feature=youtube_gdata
Post by: VileZambonie on July 24, 2010, 05:04:28 pm
A tire machine is designed to protect the wheel from any damage. You would have to be a moron to ruin one of those wheels on the machine. I woulda just paid someone $10 bucks to mount them on there for you but as others have said, just remove the valve core lay the wheel on something so there's no pressure on the tire. Try to seal the bead area by gently lifting upward on the tire as you fill it.
Post by: Layne on July 24, 2010, 08:58:43 pm
Blew out a newer bfg for my s-10 doing that. Wasn't happy
Post by: Irish_Alley on July 24, 2010, 11:15:25 pm
how much fluid did you use?
Post by: three8six on July 25, 2010, 02:13:26 am
I too have done the lighter fluid trick atleast 12 times but never on anythings that was mine, or daily driven hahah.
Post by: Irish_Alley on July 25, 2010, 02:57:48 am
never used lighter fluid before
(http://www.naioa.com/v2/modules/Forums/images/smiles/flamethrowingsmiley.gif)
Post by: Layne on July 25, 2010, 03:27:09 am
My dad and I did it when I was younger, probably a ton lol
Post by: Canadian 4X4 on July 25, 2010, 12:14:21 pm
when we do semi tires we just take the core out and hook the hose right on the valve stem with out using any attachment then once you get it to seat quickly pull the hose off and put the core in. or if that wont work we have an old propane tank with a valve on the side and a spout on the top and just fill the tank with 100 psi of air put some ear plugs in and aim that blast of air right at the bead and it will fill the tire with real quick burst of air and almost instantly be seated. Its extremely loud though ear plugs are definitely a necessity.
Post by: Stewart G Griffin on August 23, 2010, 10:09:18 pm
Sgt:
You could try the ratchet strap/rope around the tire(doesn't always work) or even the compressed air blast method(which i don't like).  i especially don't like the torch method.
What i've used is something known as a tire donut.  Here's a link:
http://www.ribetproducts.com/home.php?cat=85
It's pretty neat---it creats a seal between the rim and tire bead and as the tire inflates and pressure goes up, the donut simply pops out.
i prefer doing it myself too when it comes to tires.
wow---didn't notice the date.  Oh well, still useful info.
Post by: howlinwolf on August 23, 2010, 10:35:54 pm
all these guys, but im suprized no one mentioned this. A lot of places may use dish soap as a lube, BUT the dish soap never really evaporates, leaving a possible sippery situation if your under load which may allow the bead to rotate on the rim.
Post by: Stewart G Griffin on August 23, 2010, 11:11:16 pm
Thanks for the info;  i've always wondered about that---sometimes when i dismount tires there seems to be still a little soapy residue.  Not a whole lot but definitely an oily condition.  i'll sometimes not use soap if i can get away with it.  Not for the reasons you mentioned though----mostly because it's more work!
Post by: frickenbored on August 25, 2010, 10:26:44 pm
I've mounted tires by hand at home and I've worked at a tire shop using the machine.  The machine is 100x  faster and easier.  Those machines are designed to work without scratching or bending the wheel. (by the way you would have to do something catastrophic to actually bend the wheel.)  The only time you have to worry is if you have spokes that stick up past the rims edge, I have seen people mess those up because they dont set the duckhead to the highest part of the spoke.
Post by: Irish_Alley on August 26, 2010, 12:32:06 pm
Try this. At northentools.com item number is 145645-1101 or 14599559-1101
http://northerntool.digby.com/shops/web/northerntool?cmd=searchResult&itemId=145645&vendorId=110 kind of the same ideal as the starting fluid but just a little more money
Post by: 86gmc23 on August 26, 2010, 02:49:59 pm
They work pretty good when needed. We got a Cheetah at my shop for the tires that need "persuading" .
But overall you would have to be incredibility incompetent to bend a rim, I can see some idiot scratching it tho.
Post by: Jim Rockford on December 30, 2010, 05:53:33 pm
Soap is no problem, you have to have something on the bead to seal it to the rim, otherwise you run the risk of having a slow leak at the bead.
Soap doesn't hurt.
