73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: BIG CHEVY on July 31, 2010, 05:13:47 pm
Title: level body
Post by: BIG CHEVY on July 31, 2010, 05:13:47 pm
79 k-10.       could someone be so kind as to bless me with this answer?
how do u measure a truck to level? mine is low in back. floor to bodyline?  tire to wheel well? wheel wells even front and back?
thanks in advance.  need to get this baby even. where to start?
Title: Re: level body
Post by: Blazin on July 31, 2010, 06:53:12 pm
By eye. Jack the back end up until it looks like the correct stance. Measure how much you jacked it up. Then if your rear springs are not beat slip a set of blocks in. If they are flattened out then you might want to consider a pair of new rear spring packs.
Post by: fitz on July 31, 2010, 10:27:35 pm
Like Blazin said, You have to do it so it looks right to the eye.
These trucks didn't seem to sit level from the factory. To me they look like the rear wheelwell is too low.
This can become more obvious as the trucks get older and the rear springs sag. Lift kits that use new front springs and blocks on the old sagging springs only make the situation worse.
When I put the lift in my truck I had a hard time getting it to sit right.
I swapped in 3 sets of front springs trying to make it sit level, it just didn't look right to me.
I finlay ended up using a 6" rear spring with a 4" front spring and had some spring shackles made to level it out. It's just a way to fine tune it to get it to look right.
Post by: 1980c10 on July 31, 2010, 10:46:29 pm
I used the wheel well to tire gap front and back. the rear is a little lower than in the front- I set them equal to give it just a llittle forward stance I used the body line for a measurement to check side to side.
