73-87 Chevy _ GMC Trucks => Performance => Topic started by: Swims350 on August 16, 2010, 01:20:47 pm
I just done a quick search on some small block chevy head stuff and came up with some good info and charts figured I'd pass it along.
http://www.ryanscarpage.50megs.com/combos1.html
that one is dyno proven combos.
head comparison, aftermarket and stock.
http://www.purplesagetradingpost.com/sumner/techinfo/heads1.html
RHS heads.
http://www.racingheadservice.com/Information/Technical/FlowCharts_New.asp
That is some helpful info. I used to always compare engine combos to that "ryanscarpage".
I was gonna post of the link to mortec which shows most of the head and block casting numbers, but it looks like the site has been shut down.
I go to chevymania.com all the time for casting numbers for heads, intakes, cranks, blocks, suffix you name it.
This is another good one. It was from this article that I chose to buy the Dart Iron Eagle heads (same as the 'Aerohead Racing' heads they test, which are the Darts).
http://www.chevyhiperformance.com/techarticles/0608_chpp_chevy_cylinder_heads/index.html
nice I bookmarked that one too.
