73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 4X4green79 on September 13, 2010, 03:06:28 pm
Title: Transfer case mount bolt length
Post by: 4X4green79 on September 13, 2010, 03:06:28 pm
I recently aquired a 79 chevy 4X4 and found the transfer case was not bolted to the crossmember.  I was trying to figure out the size and length the bolts should be that bolt through the crossmember into the transfer case.  I just bought the lower rubber mounts.  Transfer case is 205.  Also, the transmission (Th350) is leaking from where the linkage goes into the side of the trans on the drivers side...Is this an easy fix??  I'm guessing its just a bushing
