73-87 Chevy _ GMC Trucks => Performance => Topic started by: Tazman on September 13, 2010, 07:00:26 pm
My truck just turned 156,000 miles and for the second time it two months the intake maniflod has come loose.I have owned several vehicles and have never had this happen.Is it normal?Thanks
That is not normal. When it came loose the first time did you replace the gaskets and properly torque the manifold down?
Need more information.... What's your engine? What kind of intake is it?
First time just torqued the bolts down.It is a 350 with the stock aluminum intake on it.Did learn last night that the gasket is gone in one corner so thinking that the intake could be worn from age (156,000 miles) I am planning to replace it.Thanks
Are you sure that aluminum intake is stock?
I think Tazman has TBI which has a aluminum intake.
Good catch, I was thinking maybe be was dealing with an offshore intake that was warped.
I replaced the intake with an Endlebrock performer yesterday,a welcome change to the horsepower.Stock intake had seen it's use after 156,000 miles.Thanks to all of you for your input.This site is the best!!
