73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: valley 84 on September 17, 2010, 10:23:12 pm
I HAVE A 84 CHEVY STEPSIDE SHORTBED 2WD I HAVE IT DROPPED IN THE FRONT WITH DROP COILS AND THE REAR LEAF SPRING FLIPPED SO THE PROBLEM IS THAT FROM THE REAR IT LOOKS LIKE ITS DRIVING CROOKED...BED DRIFTS TO RIGHT THAN STR8ENS OUT IM ON STOCK 15'S DOES ANY ONE KNOW WHAT THE DEAL IS???THANKS FOR THE INFO... ??? :-[
When you flipped the rear leafs how did you get them to align with the perches? It sounds like your axle is skewed, and your CAPS LOCK BUTTON IS STUCK. Welcome to the site. Post up a pic of your rear springs/axle and somebody can probably help you figure it out.
Take some measurements, center of hub front to rear both sides see if they're the same. Sounds like the rearend is not in the alignment holes. Was it ok before you flipped the rearend?
THANKS FOR THE PROMPT RESPONSE ILL USE THE TIPS AND POST THE RESULTS....THIS WEBSITE ANSWERS FAST IMPRESSIVE WORK GUYS!! ;D ;D ;)
I think his doomed he button must be stuck all the time :'(
Turn you caps lock off.
If it wasn't crooked before, make sure you put the spring perches on correctly.
