73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Gusgus74 on October 04, 2010, 11:52:53 am
Title: Coil wire
Post by: Gusgus74 on October 04, 2010, 11:52:53 am
Does anyone know the color of the wire that powers the coil. I'm trying to hook up a new HEI  and I need to replace it with a non-resistor type wire but I'm not sure which of the bulkhead wires feeds the coil.
Title: Re: Coil wire
Post by: Captkaos on October 04, 2010, 01:05:14 pm
Are you going from Points to HEI?  If so you cannot use the power wire to the coil from the points setup.  You need switch power off the fuse panel.
Post by: Gusgus74 on October 04, 2010, 03:37:55 pm
Yup, points to HEI. Is there a fuse panel circuit that provides switched power at start AND run? I was going to replace the resistor wire with a regular wire to feed the HEI.
Post by: Captkaos on October 04, 2010, 04:00:36 pm
If you remove the resistor wire are you completely removing it and replacing it with a 12 gauge replacement?
I ran mine from the fusebox to the HEI BAT terminal on my 73.  It was labeled switch, but anything that is open and hot with the ignition on will work.
Post by: Gusgus74 on October 04, 2010, 04:17:27 pm
are all switched circuits "Hot" even while cranking? You can leave an inch or two of resistor wire and still get full voltage at the coil. I've done this with other conversions and it worked fine but if I can find a terminal right off the fuse panel I'd rather do that.
Post by: VileZambonie on October 04, 2010, 04:20:40 pm
Don't leave any of the resistance wire there. Go directly from the fuse block and verify using a test light that you have switched B+ and while cranking.
Post by: Captkaos on October 04, 2010, 04:33:55 pm
Ditto, you don't want to leave any of that wire.
Post by: Gusgus74 on October 04, 2010, 05:00:32 pm
Ok. Thanks for everyones responses.
