73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: tmedic on October 05, 2010, 11:07:03 am
Title: Need Help. 87 Custom White smoke
Post by: tmedic on October 05, 2010, 11:07:03 am
I have a 87 Custom Deluxe. It was doing great until I towed a small trailer. When I was backing the trailer white smoke started coming out both exhaust pipes. Oil level is fine. Truck has a 305 TBI. The first time it did this I blew it off. The second it was a little more smoke and it blew out a big puff when I put the truck in drive but then cleared up. I also noticed a 5 mpg drop in my fuel economy at the same time. Any idea's would be appreciated.
Title: Re: Need Help. 87 Custom White smoke
Post by: Unofficial on October 05, 2010, 11:12:31 am
Sounds like blow by. That's what happened to me with my 350 tbi. I was blowing oil out of the valve covers and eventually the exhaust started smoking pretty bad. How old is the engine?
Post by: tmedic on October 05, 2010, 11:16:28 am
Original engine. I did about 3 months ago switch to a true duel exhaust. If that makes any diff.
Post by: Grim 82 on October 05, 2010, 11:18:35 am
Did you check your coolant level/condition?
Post by: Unofficial on October 05, 2010, 11:19:11 am
Well it might be due for an overhaul if it gets much worse... My 305 tbi did that but only on start-up. I've since put in a 350 tbi that I blew the rings in which is getting replaced as of now.
Post by: tmedic on October 05, 2010, 11:21:43 am
Engine coolant levels and condition are good. Oil levels and condition are good too. By overhaul what do you mean? I'm guessing more than the typical fluide change and plug/wire change.
Post by: jaredts on October 05, 2010, 11:25:15 am
Try removing the pcv valve and the pcv vent hose from the valve covers and start it up.  If a significant amount of smoke comes out of the valve covers then its worn rings.  Of course a cylinder leakdown test would be the best thing.
Post by: tmedic on October 05, 2010, 11:28:55 am
Just tried that. Smoke did come out   about half the amount you'd get from blowing out a match.
Post by: Captkaos on October 05, 2010, 02:21:16 pm
Sounds like the seals in the heads are on their way out.  Did you do a leakdown test?
Post by: tmedic on October 05, 2010, 02:33:16 pm
No I don't know what a leak down test is.
