73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 75Chev on October 12, 2010, 06:48:50 pm
Title: NV4500 swap
Post by: 75Chev on October 12, 2010, 06:48:50 pm
Hey everyone. I'm swapping out the SM465 in my '75 chevy for a NV4500 5 speed out of an '88 chevy 1 ton pickup that had a 454.  Will the spline and size of the input shaft of the NV4500 be the same? Also, what about the bell housing? is it interchangeable?
Title: Re: NV4500 swap
Post by: 1980c10 on October 12, 2010, 07:08:40 pm
not too sure about most of that but you will need to modify the crossmember and most likely convert to a hydraulic clutch assembly. good luck and keep us posted of your progress
Post by: 75Chev on October 12, 2010, 07:25:43 pm
I was told the NV4500 could be used with a manual clutch assembly?
Post by: Irish_Alley on October 12, 2010, 08:04:43 pm
I know the nv3500 93 and older you can swap bell housings with the 465. Here is some prices on a adapter plate if you wana keep the 465bell housing http://www.nv4500.com/product_info.php/cPath/3144/products_id/24275
