73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: KILLERC10 on October 13, 2010, 10:58:18 pm
Title: MICKEY THOMPSON ON RALLEY?
Post by: KILLERC10 on October 13, 2010, 10:58:18 pm
HEY GUYS WHATS THE BIGGEST MICKEY THOMPSON TIRE I COULD PUT BEHIND A 87 SUBUBAN RALLEY WHEEL ON MY SHORT BED C10. LOOKING FOR A FAT TIRE LOOK IN THE REAR BUT WANT TO USE THE STOCK RALLEYS CAUSE THEY LOOK SO GOOD ANY PICS OF WHAT YOU GOT WOULD BE HELPFULL
Title: Re: MICKEY THOMPSON ON RALLEY?
Post by: screamin86 on October 13, 2010, 11:59:52 pm
There are companys that can widen wheels if you need to.
Post by: HAULIN IT on October 14, 2010, 07:43:28 pm
You can get away with the 315/60 15 or the 325/50 15, both are 11" wide tread. Mickey Thompson doesn't reccomend it, but I ran the 325/50's on an 8" wheel for a couple years. They looked a bit "balloony", but wore ok. Lorne
(http://i163.photobucket.com/albums/t285/HAULINIT/LornesTruckPRP-1.jpg)
(http://i163.photobucket.com/albums/t285/HAULINIT/AnotherPRPday001-1.jpg)
Post by: Lucky Jeff on October 20, 2010, 01:02:31 pm
hmmm, that statement is a little weird. 315 and 325 is the width of the tire... My 325's are 12.9" wide (That's what the website shows, if you do the math, it's 12.79. 315 would be 12.4).. The width doesn't change based on the other numbers, just the height....
Post by: VileZambonie on October 20, 2010, 08:17:21 pm
I have a set of 325/50r15's and they're about 12.5" wide
Two tires of the same exact size can be different by a few millimeters
Post by: Lucky Jeff on October 20, 2010, 09:57:09 pm
A few millimeters definitely, but not almost a couple of inches like he's saying.
Post by: Da67goatman on October 21, 2010, 12:21:01 am
The tires won't be that wide when you mount them on 8" rims.  They'll shrink to around 11.5 section width and tread width is narrower yet, so he's probably pretty close.
Post by: three8six on October 21, 2010, 11:29:40 am
Well tire width and track width is separate.....so yea the tire could be 12 inches wide but be so ballooned its truck width could be maybe 10 inches. Track width is more or less the amount of the tread contacting the pavement....
Post by: Lucky Jeff on October 21, 2010, 09:28:50 pm
You can't shrink the width of tread.... Putting them on 8" wide rims just pulls the sides in and screws up the contact patch. And then what's the point of having wider tires if you aren't using it all? Might as well use proper wheel and tire fitment. The only reason you'd want to do that is so you can run much lower air pressure for the track and get the contact patch back to normal. Which isn't 11" on a 325 tire.
Post by: HAULIN IT on October 22, 2010, 01:22:43 am
Well Jeff, I clearly stated tread width not section width which is what the 315 or 325 numbers mean. I mentioned the 315's because if he is hunting a BIG (both wide & tall) the 315/60 is about 2" taller than the 325/50.
 As mentioned, tires from different companies or even just a different type of tire can have a different width (especially tread width) even though they have the same xxx number on them. Is there some 325's that have more than 11" of tread width?...I don't doubt that a bit.
 Here is the Mickey Thompson ET Street radials that are on my truck today (mounted on 10" wheels) fairly new with 33 psi in them sitting in the driveway.
(http://i163.photobucket.com/albums/t285/HAULINIT/etstreetradial002-1.jpg)
(http://i163.photobucket.com/albums/t285/HAULINIT/etstreetradial001-1.jpg)
 Here is an old one that is "squared off" a bit after 100 passes or so & a bunch of miles
 (http://i163.photobucket.com/albums/t285/HAULINIT/etstreetradial008-1.jpg)
 (http://i163.photobucket.com/albums/t285/HAULINIT/etstreetradial003-1.jpg)
 I don't have any of the 315's to measure, however both Summit & Jeg's list them in the newest catalogs as being 11" tread width also. Is the one a 1/4" different in width than the other? probably.
I stand by my original unedited post. Lorne
Post by: Lucky Jeff on October 22, 2010, 05:24:39 pm
I know what the numbers mean  ;). Overall width is more accurate with 325 (like I said, do the math and you will see that 11" is 280mm) and not just the tread width. For fitment, overall width is what has to be known more then tread width. But oh well, they fit and that's all that matters.
Post by: VileZambonie on October 22, 2010, 10:00:41 pm
I had Hoosier qucktimes in 325/50R15's and they were almost an inch wider than the same size BFG drag radials.
Post by: Lucky Jeff on October 23, 2010, 12:48:16 am
yea that is a regular problem. Different manufacturers measure their tires differently. If you are wanting to buy, it's better to over compensate.
Post by: HAULIN IT on October 23, 2010, 08:28:40 pm
I give up...The original poster hasn't been on here in a week & Jeff & I are one or more of the following: Speaking Two different languages,
               He can't read & comprehend a sentance
               He can't remember what his point was of posting in this thread was in the first place.
                                              We'll try again another day  ;) Lorne
Post by: Da67goatman on October 23, 2010, 08:46:00 pm
I'll back you up on that. let's try another day.
Post by: 82BlazerMan on October 31, 2010, 10:32:03 pm
Did you run tubes with those Hoosiers?  Summit says their required.
Post by: KILLERC10 on January 04, 2011, 10:35:12 pm
So a 315-60 might fit a 15x8 ralley?
Post by: bake74 on January 05, 2011, 10:39:00 pm
     All that back and forth and KILLERC10 still didn't get his question answered..... ::)
Post by: Captkaos on January 06, 2011, 02:08:43 pm
Yes, see Lorne's first post.
Post by: 82BlazerMan on July 13, 2011, 12:21:22 pm
Hey I'm thinking about getting some Hoosier 325/50/R15's but they say they need tubes?  Since I'll be running on the street and I won't really be hot rodding it, could'nt I mount them without the tubes?
Post by: beastie_3 on July 14, 2011, 02:35:48 am
might need the tubes because the tires are more porous than other tires? not a tire expert.
Post by: chevymanrob on July 17, 2011, 05:31:39 pm
if they suggest tubes and you plan on NOT having to air the tires up every day you drive it then buy tubes. my old ET Streets would bleed air thru the sidewalls. one was worse than the other. think 15-20 ponds PER DAY!!! funny, after i bought a smaller set with tubes they never lost a pound again :).
moral of the story, buy tubes and call it done or buy radials.
Post by: 82BlazerMan on September 14, 2011, 01:04:16 pm
These are 29x12.5 R15 Mickey Thompson Sportsman Pro's.  They have about 3/8" clearance each side.  Perfect!
(http://pic80.picturetrail.com:80/VOL962/4286799/22337421/398477103.jpg)
Post by: 73k5 on October 06, 2011, 10:34:42 am
Im not running tubes in my 315/60/15 Hoosier D/R on my turbo stang and they never leak down...
(http://i34.photobucket.com/albums/d141/ndawedz/95%20Cobra/305.jpg)
