		73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: rroeder96 on October 23, 2010, 09:52:38 pm
				Here's the thing i would like to remove my ac without hurting my heat in the truck i never use ac anyways, figured it was a waste of time to have in the truck. My question is can i remove all of the ac parts without losing my heat in the truck or are the two not even connected together and don't matter anyways. Thanks
				Yes you can but if you have no better reason to remove it than that you should keep it. Makes the truck more valuable with it as well.
				I guess it depends how hot it gets. I took mine off. It wasnt worth it to ME to fix what needed to be fixed.
				they make aftermarket boxes that replace the evap box. Once you remove the evap and box shell, you replace it with this piece and your done.. its about 150.
 clint
				Check out acdelete.com
				thanks for all the info when i bought the truck somebody removed all the ac parts in the engine area so i decided to remove it the rest of the way thanks again...
				Your lucky not to need AC. Down here I would not even consider buying a truck without AC.
				well even when i lived in florida i never used one i just like the windows down lol...
				I guess I must getting old or something...
				thats what my father in law says to hes getting old so he now loves the ac but im 30 and still dont care much for it...now my wife loves it tho in her car..
