73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: bigfosty on October 27, 2010, 07:35:24 pm
This might sound confusing but I'll try my best to explain it clearly. My passenger side tank is leaking. When I switch to that tank after about 15-20 seconds fuel starts pouring out from the top of the tank. I am assuming this is a fuel line, perhaps a return line given the short wait before fuel starts leaking out. This has been going on since I bought the truck and I haven't bothered to fix it since I have the other tank. Now though it seems when I fill the drivers side tank it starts leaking, but it leaks from the passenger side, from above the passenger tank. It's a much smaller leak than the original one and it seems to either be intermittent, or only leak when there is a certain amount of fuel in my drivers side tank. I haven't driven it enough to be able to tell however if it's intermittent or only leaks when theres so much fuel. Anybody got any ideas? I haven't looked super close due to the weather right now, but it looks like the only way to get a clear view of the lines is to drop the tanks? Anything I need to look out for when doing this? Are the lines long enough to drop the tank without disconnecting them? Thanks for any help guys, much appreciated.
I am only speaking for myself, but honestly, after having been there and done that I would remove the bed instead of dropping the tanks. Then get the 3 different sizes of fuel hose and replace every inch of rubber, including the ones for the selector switch.
I thought about this but it looked like part of the tanks were under the cab and I would have to drop them anyways. Not the case? It's a 75 k-10 if that makes a difference.
The front parts of the tanks extend under the cab, but the hoses and sending unit are accessable without the bed on the pickup.
