73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Da67goatman on October 30, 2010, 07:07:51 am
Title: Throttle Adjustment
Post by: Da67goatman on October 30, 2010, 07:07:51 am
My pedal does not pull the throttle all the way open, is there some way to adjust it?  The pedal hits the floor at about 3/4 throttle.  Thanks in advance.
Title: Re: Throttle Adjustment
Post by: Dr_Snooz on October 31, 2010, 12:15:37 am
I would start by making sure that you don't have any bent brackets or arms. If that all checks out, look into buying a new adjustable throttle cable from Kragen. I used a Spectre one off the shelf.
Post by: Irish_Alley on October 31, 2010, 04:28:31 am
The cable you should have to adjust I would look at something to do with the carb even if your bracket is bent you still should have the same throttle movement
Post by: Da67goatman on October 31, 2010, 09:53:08 am
Its all factory stuff from cable to throttle body.  I'll see if its bent anywhere.  Is there no adjust-ability from the factory?
Post by: Grim 82 on October 31, 2010, 12:49:19 pm
I bent the arm at the pedal to get a little more travel on mine. Just don't break it where it pivots at the floorboard.
