73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: N2TRUX on October 31, 2010, 09:56:47 am
Title: What did you do to your truck today?
Post by: N2TRUX on October 31, 2010, 09:56:47 am
Today I am going to pick up a few more parts for my 77 Cheyenne. I got new brakes last week, and plan to mock the fronts up. I need to work on the Ride Tech E3 install that I started before Goodguys, but never quite finished. I will try posting pics later.
What did you do to your 73-87 truck today?
Title: Re: What did you do to your truck today?
Post by: velojym on October 31, 2010, 10:56:47 am
Dumped some stop leak in the engine and took it for a ride to the airport. Then I took some pictures in front of our DC3. :)
Post by: eventhorizon66 on October 31, 2010, 12:24:47 pm
Gave it a rest and carved a jack-o-lantern.  ;)
Day before yesterday, I changed a slave cylinder (concentric style) on a '99 F150, on my back, in the driveway. >:(
Post by: bobcooter on October 31, 2010, 02:35:42 pm
Fixing to order some much needed goodies for mine!
Post by: cvbear on October 31, 2010, 02:57:23 pm
Topped off the power steering fluid, (leaking steering box) and replaced the oil pressure warning light sender with a guage sender.  Yesterday I installed some new gauges with a tach and I am working on the oil and temp senders.
Post by: Grim 82 on October 31, 2010, 03:06:56 pm
Pretty much just standing around swearing at it.
Post by: project85 on October 31, 2010, 04:00:03 pm
recharged the battery not sure if its gonna hold a charge. then fired it up just to hear it run  :)
Post by: Bitzer! on October 31, 2010, 04:06:25 pm
With most of the front clip (learning the terms!) painted, I decided to make a start on the rad core panel. The metal worm had eaten away where the inner fenders bolt on. Wizzed down local parts shop and bought some sheet metal.
Cut out all the airflow (rust holes) measured & cut the new metal and fabbed it into shape. Set the welder up, cleaned all the metal and................. ran out of gas  >:(
Promptly shut garage door and put the kettle on!
Post by: beastie_3 on October 31, 2010, 04:48:23 pm
X2
Post by: zieg85 on October 31, 2010, 07:52:56 pm
Absolutely nothing....
Post by: Lt.Del on October 31, 2010, 08:24:48 pm
drove it
Post by: N2TRUX on October 31, 2010, 08:58:33 pm
Saturday I went to a buddies house (Subtle71) and helped him lower his truck. He and a a couple friends had already lowered the rear earlier in the week so all that was left was the front.
Today I picked up a few more parts from the guy that I bought all the goodies from last week. Still have more to look at next week, but I may have some 73-80 sheet metal coming available.
This afternoon I finally worked on my E3 system again. I discovered I had a broken ride height sensor, so I pulled them all off to inspect and start fresh.
Post by: Irish_Alley on October 31, 2010, 09:01:56 pm
Thought of how much fun I had yesterday now how big is my bill going to be to fix it
(http://i333.photobucket.com/albums/m387/rebel_cowboy_83/IMG_20101030_185206.jpg)
Post by: VileZambonie on October 31, 2010, 09:12:51 pm
I sanded the firewall again and touched up a few spots. Welded the patches in the pass door and primed it. I also ordered some door hinges for it.
Post by: Blazin on November 01, 2010, 01:04:03 am
Dropped the motor in yesterday. Went out to dinner, then to a Halloween party. Today I assembled a bunch of it, and fired it. Need to move the dist. I am off a tooth or two. Still need to put the radiator hoses etc. in.
Post by: benzesrule on November 01, 2010, 05:53:45 am
I started to wire up the snow plow. I installed dual batteries.
Post by: bfofish on November 01, 2010, 04:33:40 pm
Finally got it home  ;D
Post by: Da67goatman on November 01, 2010, 07:27:11 pm
I didn't do too much, just replaced and re-aimed my headlights, reinstalled trans pan and filled tranny, bent gas pedal to achieve full throttle, reinstalled diff carrier and filled diff before calling it a day.
Post by: 1980c10 on November 01, 2010, 11:02:15 pm
picked up a chrome shifter from the u-pull it yard. didn't realize they made 'em that way. also looked for a parts truck. planning some upcoming winter work while the truck is off the road.
Post by: repo on November 02, 2010, 12:39:49 am
door strikers
Post by: HOTRDCHVY388 on November 02, 2010, 04:54:27 pm
tried to put headers on it but they hit the frame.....
Post by: screamin86 on November 02, 2010, 05:10:17 pm
Started it and let it run for a few minuites since I haven't ran it for a few days! About to put on all aluminum welded radiator on with electric fans and a new flexplate!
Post by: SUX2BU99 on November 02, 2010, 05:13:38 pm
Last weekend I yanked my buckets and the amp rack, stripped it down and am going to install some 'new' circa. 1988 Alpine and Rockford amps.
Post by: N2TRUX on November 04, 2010, 10:01:52 am
I ordered the brake line kit that I need to convert my front brakes to Wilwoods. As usual the best deal to be had was from Summit.com
(http://www.wilwood.com/Images/BrakeKits/BrakeKit_Photos-Large/kit_140-10815-DR-lg.jpg)
Post by: project85 on November 04, 2010, 02:00:37 pm
brought the truck to work to change plugs, wires, cap. rebled brakes. not too bad a day.
Post by: Canadian 4X4 on November 04, 2010, 03:53:29 pm
Took the truck off the road for the winter :'(
Post by: figure843 on November 04, 2010, 07:36:14 pm
Looked at it. Just painted it last weekend. Now I have to put it back together.
Post by: Slooby on November 04, 2010, 08:48:31 pm
Took off door panels to sand down and get all the old junky paint off of them from previous owner.
Post by: N2TRUX on November 05, 2010, 10:49:35 am
Got my shipment from Summit Racing yesterday...:)
(http://static.summitracing.com/global/images/prod/large/rus-656022_w.jpg)
(http://static.summitracing.com/global/images/prod/large/rus-641291.jpg)
(http://static.summitracing.com/global/images/prod/large/aer-fcm2622.jpg)
Post by: bobcooter on November 05, 2010, 11:41:49 am
I recieved my full coverage floor mat from Chris yesterday. Today I just bought all the stuff I need to start on some body work.
Post by: Bitzer! on November 05, 2010, 01:22:32 pm
Today > Finished repairing rad core panel. Moved stuff out the garage and winched(I'm on a slope) the chassis cab into the once big space. Then put everything back in around the truck. It's tight in there but I'll have to make room to prep and paint.
Post by: TxFiddler on November 06, 2010, 10:37:12 am
Walked passed it, again, wishing it was back together.  Still getting the old paint off the big block that's gonna go in.  Got a shipment from Summit.  Wished there was more "free" time in the work week.  Gonna paint the engine this weekend and get the old engine out.  Wondering what tranny to run....mind is running all over the place.....
Post by: snibook7537 on November 06, 2010, 01:05:05 pm
putting on some new pads and rotors on the k30. then gotta fix a leak the trans has. I just put a clutch in it and looks like the transfer case will be coming down again. Stupid gasket. Then gotta check the rear brakes.
Post by: 4x4orbust on November 06, 2010, 06:16:37 pm
today,   i walked by it when i got home from work and said "why don't i drive this every day?"  then realized it's because it's a pain to move all my tools from one truck to the other....
tomorrow i'm hoping to wash and wax it.
Post by: bobcooter on November 06, 2010, 09:52:29 pm
Pulled the instrument cluster out, pulled dash pad out and removed old, funky AC vents. Redid the band on the front of the dash and got new AC vents ready to go in. Cleaned up instrument cluster. All looking pretty good. Tomorrow, put it all back together then install new dash cap. Things are lookin up.
Post by: magicmarker77 on November 06, 2010, 10:44:19 pm
Pulled the passenger side door, un bolted the hood and fender off my donner. Stood around and looked at it thought about weather to go step side or fleet........ ???
Post by: project85 on November 07, 2010, 06:56:00 am
Step side :o
Post by: chevyguy74 on November 07, 2010, 02:34:05 pm
i hooked up my bowtie tail lights and the license plate lights
Post by: N2TRUX on November 07, 2010, 06:33:01 pm
I cleaned my 77 up and took it out Saturday night. Went to a local car cruise and enjoyed the weather. Today I took voltage reading of the ride sensors on my Ride Tech E3 system. Trying to determine why they aren't calibrating.
Post by: 1980c10 on November 07, 2010, 09:11:26 pm
I installed my chrome shifter today. Removed the front seat-hooked up a new amplifier/amp combination just to take out because it didn't sound good, left the seat out deciding weather or not I want to do the rest of the stereo or wait-guess I'll put the seat back in later and order some new shallow subs for behind the seat and build a box at a later time.  Took my daughter for walk through the u-pull-it didn't find much today. Though a little bit about how many hours really goes into old vehicles to make them nice.
Post by: Bitzer! on November 14, 2010, 03:32:47 pm
another productive weekend! driver side rear door off and binned, donor door fitted (and totally stripped) it lined up really nicely but the driver door had 1/2 inch of filler in so that's been ground out back to bare metal ready to skim.
New cab mountings fitted drivers side and most of the wires through the bulkhead disconnected.
Think I might have to take a leaf out of Vile's book (but not so drastic!) and cut out the bulkhead and replace with smooth sheet. I know it's more work but it's gotta be quicker than trying to sort out what's there!
Post by: bobcooter on November 14, 2010, 10:31:10 pm
Was all busy last weekend with the interior. But got derailed Monday when I had a heart attack at work. Just got out of the hospital Friday afternoon. Everything is kind of on hold now.
Post by: Layne on November 14, 2010, 10:31:51 pm
Hope you feel better soon
Post by: bobcooter on November 14, 2010, 10:33:29 pm
Thanks. It will take some time to get sorted out.
Post by: 84shortwide on November 15, 2010, 04:28:13 am
Hope you get well soon,
I bought some plug wire looms from Summit.....now i just need the wires
Post by: Blazin on November 15, 2010, 05:28:22 am
Heart attack, oouuffff. Thats not good, hope you get back on track soon, and feel better. Friend of mine had one early this summer, he is just starting to get back to normal. He is three years younger than me. Got him to quite smoking though. I gave him some extra incentive too. I told him go ahead keep smoking, kill yourself, I will take care of your wife when your gone!!  ;D
Sat. I fabricated top brackets for the oversize radiator, and the fan shroud on the 86. Yesterday I installed the caliper brackets, rotors, and calipers on my 55.
Post by: Grim 82 on November 15, 2010, 09:02:03 am
Hope you're feeling better bobcooter.
Should be getting the truck back from the trans shop with a new valve body today.
Post by: N2TRUX on November 15, 2010, 10:24:55 am
Sunday I went and bought another load of 73-80 parts. I will post pics of my latest haul.
Post by: Bitzer! on November 15, 2010, 02:44:27 pm
Hope you're feeling better bobcooter.  x2 dude
Today > fitted cab mounts passenger side. Little and often  ;)
Post by: N2TRUX on November 15, 2010, 08:21:08 pm
Mother load....
Post by: GUITAR1989 on November 16, 2010, 03:56:43 am
My stearing wheel and overflow tank are supposed to get dopped off today :)
(http://i54.tinypic.com/f9e3vp.jpg) (http://i54.tinypic.com/x25p1x.jpg)
Post by: bobcooter on November 18, 2010, 05:09:25 pm
Thanks to everyone for the well wishes. I should have known better. I'm 49 and I ate everything I wanted whenever I wanted and smoked two packs of Marlboros a day along with about a gallon of coffee. Just like I did when I was 20. I guess it was just a matter of time. A real wake up call for sure. Getting lean and mean now and quitting the smokes. I was actually in pretty good shape believe it or not, but I think it was the Marlboros that got me.
 If you don't smoke; don't start. If you do smoke you need to try to quit.
Post by: Grim 82 on November 18, 2010, 05:42:21 pm
If I had a nickel for every time I quit smoking....well maybe it'll happen for 2011.
My water pump blew chunks and died yesterday so I'm off to the garage to fire up the nipco heater and see how big of a mess I can make.
Post by: KY..Rob on November 20, 2010, 09:14:29 pm
I started cutting out the passanger floor board and rockers, got the cab corner off and started grinding on the inner cab corner. Getting ready to place an order with Chris on some parts.
Blazin, I hope your ready for a crap load of questions..LOL
Rob.
Post by: N2TRUX on November 21, 2010, 07:44:59 pm
I worked yesterday so I didn't get much done. Today I rewired a Bro-in-laws utility trailer because the dog hate the harness up. After that I spent some time organizing all the parts I bought last week. Later I pulled the seat in my 77 so I could remove the Ride Tech E3 ECU. It is going back to Ride Tech for updates.
Post by: mach1mustang351 on November 21, 2010, 10:04:22 pm
Finished up adding my Auxiliary trans cooler and engine oil cooler.  Also finished plumbing the dual tanks.  Putting off the wiring project as long as possible to make the TPI work :)
Post by: topp on November 21, 2010, 10:14:33 pm
Finished up my Headlight relays and painted both my battery trays.
Started cleaning off the front axle for paint....
Post by: Sartobuilt on November 22, 2010, 09:17:20 am
Tear down, bag and label parts.
(http://i96.photobucket.com/albums/l179/Sartobuilt/IMG_0519.jpg)
Post by: Grim 82 on November 22, 2010, 09:42:42 am
Woke up to a winter wonderland outside, so I put the scoop shovel in the back, and locked the hubs in.
Post by: mach1mustang351 on November 27, 2010, 11:06:30 pm
I stripped all the undercoat off the bottom of my bed and painted on the POR 15 and let it set up.  Hopefully undercoat goes on tomorrow.
Post by: bobcooter on November 28, 2010, 04:24:12 pm
Am finishing up replacing the bed end cap and fender wells. Caulked all seams today and painted with POR-15. Waiting for second coat to dry enough to spray them with primer.
Post by: royo on November 28, 2010, 08:24:41 pm
I just finished putting new rubber fuel lines on my truck down there at the fuel pump.  They where swelled up and leaking  I believe it was the alky gas that did it lol
Post by: N2TRUX on November 28, 2010, 09:03:13 pm
I pulled the E3 ECU this week. It's going back to Ride Tech for the latest version of software. Hopefully when it comes back I can get the final stage of the install completed.
Post by: Captkaos on November 29, 2010, 05:21:03 pm
I pulled the motor out of my 85 Blazer 4x4.
Post by: Irish_Alley on November 29, 2010, 07:32:37 pm
Finally got my truck back running in the mud changed it over to a 205 due to the adapter plate braking. Only to cause a Carb problem swapped it from a Holley to a edelbrock now is tuning
Post by: jackjeckel757 on November 29, 2010, 08:04:55 pm
used the height of the bed to increase the height of an extention ladder so I could clean out my gutters!
Post by: Irish_Alley on November 29, 2010, 09:09:17 pm
Also shotgun season opened up Saturday haven't been out but have a nice size doe hanging in the shed due to my 94. On my way home from work this morning about 830 I found her laying in the middle of the road not busted up still fresh her ankles down were shattered. Now we got deer and I didn't have to sit in a stand to do it beats tracking one for sure lol. Thank God for trucks
Post by: slammed79 on November 29, 2010, 10:24:30 pm
I sold my 74 to my brother on Saturday and then flipped my Yukon Sunday morning. Luckily I had my seatbelt on, I spent the day at the hospital and have been hurting all day today.
(http://i640.photobucket.com/albums/uu122/genosis/2010-11-29_100332.jpg)
(http://i640.photobucket.com/albums/uu122/genosis/2010-11-29_100341.jpg)
Post by: Canadian 4X4 on November 29, 2010, 10:56:07 pm
Wow  :o glad to here you are alright
Post by: Lt.Del on November 29, 2010, 11:03:13 pm
Hey Slammed, I think you slammed that one pretty good. The object of driving is to keep all wheels on the ground--just a piece of free advice for ya.
glad you're ok.  Soreness will subside in a few days.
My nephew had to slam on brakes the other day to avoid hitting the car in front of him...no problem, successful.  then, WHAM!!  He got hit from behind, by someone who didn't even put their brakes on, doing 55 mph, according to the person behind that person.
It slammed my nephews chevy truck so hard, the back of his head hit  back cab window and shattered it.  Had a concussion.  It rammed his truck off the road and into a tree, totalled.
Oh, who ran into him?   A county Deputy Sheriff driving his county Explorer.  I think he was texting...no brake lights or skid marks...nothing.  The next morning, I contacted a very popular attorney around  here who knows me well from my job.  He took up the job in a heartbeat.  Waitin for pics to be emailed to me.
Post by: Bitzer! on November 30, 2010, 03:30:11 am
Started repairing the firewall. Thinks it's going to take longer than planned!
Post by: autorepr on November 30, 2010, 06:28:37 am
Yesterday I hauled 1.6 ton of #304 gravel in it but I think that's going the other way with it?
You mean what did you do to improve your truck?  Well, I put a stereo in it last night that I got for free out of a car I scraped.
Post by: Grim 82 on December 01, 2010, 10:27:08 am
Went to turn the heater down and snapped the fan control lever off. 30 year old plastic and 5 degrees outside don't get along very well.
slammed- hope you're feeling better
Post by: VileZambonie on December 01, 2010, 11:06:19 am
slammed how did that happen and why did you sell it?
Post by: slammed79 on December 01, 2010, 05:40:30 pm
Thanks guys, my left shoulder is still hurting when I move it more than a lil bit but its getting slowly better. I was dog tired and heading home from my girlfriends place at about 3:30, I must of fell asleep at the wheel because I don't remember a thing except waking up on a stretcher in an ambulance.
I sold the 74 to my brother cause he needed some wheels and I needed some cash, I haven't really been driving it anyway because my left knee is jacked up and the clutch wears me out in traffic, I'm going in for surgery in Jan. The funny thing is the 74 got better mileage than the Yukon.
Post by: greg1984GMC on December 01, 2010, 08:31:53 pm
Just recieved my new front marker lights and Chevelle SS fender emblems.
Tonight I am pricing out bed wood and stainless bed strips/bolts.
Still need to decide on what to do for tail lights and still need to order
a front bed panel and roll pan.
Lots of money going out.
Post by: bobcooter on December 01, 2010, 08:52:58 pm
To Slammed: Hope your feeling better soon!
To Irish: Deer meat is very lean and good for you. What luck!
Post by: slammed79 on December 02, 2010, 04:05:43 pm
My brother brought the 74 by for some work today, he thought the alternator went out, turned out to be the block to firewall ground strap let go, easy fix and I got to drive her around for a while.
(http://i640.photobucket.com/albums/uu122/genosis/IMG_20101202_145354.jpg)
Post by: greg1984GMC on December 03, 2010, 05:24:23 pm
ordered new rollpan.
Post by: roger97338 on February 21, 2011, 04:20:01 am
I know this is an old thread, but THAT is an awesome answer! (I was going to use it myself.)
But seriously, I lubed all the keyed locks with some powdered graphite. And forgot to buy a new dome light bulb. Again.
Post by: Blazin on February 21, 2011, 09:00:49 pm
Was up till about 3:00 AM installing new front axles, brake pads, upper and lower ball joints, and a new drivers side front center bolt!
Post by: beastie_3 on February 21, 2011, 09:13:53 pm
I installed 6in springs and shocks last week. Week prior, finished my electric fans.
Upcoming, new transmission lines, temp switch, and trans temp gauge.
Post by: thachevythang on February 22, 2011, 03:02:44 am
Pulled off the hood, the cowl. Cleaned all that out. Pulled all the emissions and the wipper motor out. Got rid of the cruise control. Getting ready to clean up the engine bay and paint it before my swap.
Post by: Bitzer! on February 22, 2011, 01:08:43 pm
Back on it! both driver side doors (outside) in primer now I have the lines right. Next to drop them off and finish the cab then turn it round and start the other side!
