73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: grinder1989 on November 20, 2010, 11:32:40 pm
Title: I'm back. With a new ride as well.
Post by: grinder1989 on November 20, 2010, 11:32:40 pm
I haven't been on here since I ditched my 74 chevy c10 project and bought a much nicer truck.  I'll be getting my new 1987 Chevy V10 here early next week.  Beside a damaged drivers door and a dent on the cab, this truck is clean.  No rust anywhere.  Literally.  I'm not too big in the off road scene though.  I just needed a good winter vehicle.  So I have some questions.  Did this truck come stock with a 12 bolt rear end and what transfer case should it have?  It doesn't have the TBI anymore and it has a stock 700r4.  Any issues with these later trannys?  I paid $2800 for it.  I hope I got a good deal.
Title: Re: I'm back. With a new ride as well.
Post by: topp on November 20, 2010, 11:41:20 pm
87 came with 10 bolt from the factory.
The later 700r4's are fine.
If the PO swapped out the TBI, you may have issues with inspection (if you have them).
Pics????
Post by: grinder1989 on November 20, 2010, 11:51:48 pm
Pics????
No pics yet.  Don't have a camera.  PO didn't swap it, the guy before him did.  Quadrajet was stuck on top.  I'll replace it with a holley 670.  I have inspection where I live but the truck will be registered in a non e check county.  No cats either.  Needs some work but nothing too hard.  I wish I knew what T case it has.  I think a 208 but I don't know.  Definitely a 12 bolt though and not a dana 60
Post by: Blazin on November 21, 2010, 12:17:15 am
T case should be a NP 208. A Dana 60 would be a full floating rear end, and 8 lugs.
Post by: grinder1989 on November 21, 2010, 12:22:35 am
I just think it's weird it has a 12 bolt.  Might even have a 205 T case.  Not sure though.  I'll have pics in a few days.  Even though it's 4wd, it makes me miss my 74. This truck is so dang clean though.
Post by: topp on November 21, 2010, 08:16:19 am
12 bolts were in these trucks for a few years.  Stronger than a 10 bolt....
If the PO didn't change transfer cases it should be an NP 208
Post by: Irish_Alley on November 21, 2010, 08:28:22 am
700r4 are 27 spline the only 205 that was 27 splines was pre 79 which wont bolt to a 700. Maybe there is an adapter for that but its not stock the only case that bolts to a 700 stock that I know of is a 208. The 12 bolt should be in older trucks pre 85 while the 10 bolt came in the front and rear of trucks of you age
Post by: VileZambonie on November 21, 2010, 08:32:01 am
The 10 bolt was fully implemented into the half tons in 1982 so no the 12 bolt is not stock.
The 208 has a full aluminum case and the 205 is cast iron so that should be an easy spotter right there.
Post by: grinder1989 on November 21, 2010, 03:22:03 pm
It was tough to tell.  It was dirty.  I'm not into the 4x4 scene, I don't know all these things.  I wonder what year that tranny is now.  Hmmm.  I'll  get you guys pics asap.  I'm so excited :).
Post by: Captkaos on November 23, 2010, 12:29:07 am
Quote
This is not true.  12bolt trucks had a MUCH smaller pinion than the 12bolt cars and it is smaller than 10bolts.
Post by: grinder1989 on November 23, 2010, 11:09:15 am
Quote
Seriously?  That's interesting.
Post by: captain carnage on November 23, 2010, 01:22:42 pm
The T-case should have a tag on it in plain view that says what it is.
Post by: grinder1989 on November 25, 2010, 09:44:44 am
It's a 208.  Here's the pics.
(http://i20.photobucket.com/albums/b206/Grinder69/P1010063.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010064.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010065-2.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010066-3.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010067-2.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010068-1.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010062.jpg)
(http://i20.photobucket.com/albums/b206/Grinder69/P1010069-2.jpg)
Post by: low budget on November 25, 2010, 12:53:42 pm
Looks like a nice truck.  Needs bigger tires and a new drive shaft, that one is MOLDY.... ;D
Just kidding, looks good and have fun with it this winter...
Post by: grinder1989 on November 25, 2010, 02:47:02 pm
Thanks.  I'll be sticking on some 33's as well as lift springs rather than the rear blocks and a crossover steering setup when I find one.  I got a few mechanical issues to deal with first.
Post by: grinder1989 on December 01, 2010, 09:04:30 am
Does anyone know how to pick the correct shock?  Mine are shot.
Post by: grinder1989 on December 03, 2010, 08:10:20 am
Anyone?
Post by: Grim 82 on December 03, 2010, 08:52:12 am
If the shocks that are on it now are correct, take a measurement fully collapsed and fully extended and cross reference them with any shock mfg's product list. Or if you know how much lift is in it contact Rancho, or similar company and get their recommendation. Or swing by your local 4wd shop and they can probably give you the ones you need just by looking at it.
Post by: grinder1989 on December 04, 2010, 08:13:20 am
All I got from Sky Jacker was to get the measurements you said.  I might just wait till summer.  $200 for a set of shocks :(.  I've already had to do the exhaust, replace the windshield, carb and linkage.  I'm kinda broke now lol.
