73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 84chevysilverado on December 08, 2010, 07:58:55 pm
I no this has alot of variables but what is the better route to build a 383 or 400 sbc? first of all what one would you build for a street driver under 400 hp on pump gas? next I cant decide whats the better route? 1, is buy an old engine strip it and get it machined and checked for cracks and build it up from scratch. 2 buy a machined new bare block build it up from scratch. 3 buy a block that has a balanced rotating assembly and do the top end myself. Once again I no there are alot of variables in this question. thanks marc
I personally would rather save a used block and rebuild from scratch, plus I think its cheaper though I have not stats to prove it. There's the old rule of thumb: there's no replacement for displacement, but now we have power adders, so its really a personal preference to what YOU want in YOUR ride.
+1
The 400 is more of a "homework" motor and they run hot. But I like em, and they have lot's of torque
have a 400 in my grandpa's k10 never had any issues with it running hot and its work truck that runs max 1 mile trips and idles ALOT, it also pulls some big boats.
400, little more bottom end than 383, more cubes doesn't hurt either, especially with a truck's weight. I also would use a seasoned block, machined by someone locally suggested, then assembled by yourself if you can do that.
They like to be warmer, I've heard, Not that they have overheating issues. My 400 runs 220 all day, which is hot for me.
I would build what I have available. The 400 small block is a great engine. It would benefit from some nice aluminum heads though.
