73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: crunchie on December 19, 2010, 07:57:14 pm
Title: True Dual Exhaust for an 87
Post by: crunchie on December 19, 2010, 07:57:14 pm
Hey dudes!
I've got a two wheel drive '87 Chevy R10 (1/2 ton pickup, only year they used the "R" designation for pickups as far as I know) and I want to put on a manifold back dual system.
I've always liked the sound of glass packs on these trucks, call me crazy, but I've never put one on myself. I found in a catalog with three letters, but it's not listed for an '87. It's part number 36-5577 and it's on page 125 of their catalog. It says it's for a 73-77. Would there be any reason why an '87 would require a different exhaust from the manifolds back?
I'm thinking either there is a difference, or they list it that way to cover their backsides when it comes to emissions compliance, but I'm not sure.
*I edited my post here to not cause problems with the website. Sorry, but there's not an offering of parts on this website that fits my needs.
Title: Re: True Dual Exhaust for an 87
Post by: zieg85 on December 19, 2010, 08:09:36 pm
Been nice not knowing you...  Merry Christmas anyway...
Post by: repo on December 19, 2010, 11:04:41 pm
the reason the system is listed for only up to 77 is because, 78 and newer cars and light trucks are required by the EPA to have a catalytic converter in place for emissions purposes. it is also illegal to tamper with these devices.
Post by: fitz on December 20, 2010, 01:37:46 am
Sounds like he doesn't follow the rules anyway.
Post by: 87454westernhauler on December 20, 2010, 08:59:56 am
we put dual glass packs on our 87 454 dually. just pipes strait off of the headers to glass packs. sweet sound ;D ;D
what are emission laws? ::)
Post by: topp on December 20, 2010, 09:14:06 am
For cars and light duty trucks it was 75 and newer...
Post by: crunchie on December 20, 2010, 11:20:15 am
Let's say I'm going to use this off-road only, for drag racing, making the discussion legal for anyone afraid to recommend anything.
Is there any reason my '87 would be different than a '77? Different cross member, gas tank, or drive shaft placement? Anything like that?
Also, I edited my original post to comply with the powers that be. Sorry, I didn't know they were a competitor. Also, I didn't see any forum rules post about that. I went looking and didn't find anything about posting competitors names. I like this forum, and the reason this is only my 2nd post is because I've been able to find answers to my questions through searching old posts. Keep it going! I love this site.
Post by: crunchie on December 20, 2010, 11:25:35 am
Hello fellow Iowegian! I'm located in Waterloo just an hour or so from you. So you're familiar with Iowa's emissions laws I'm sure.
For everyone else, there is no testing or inspections of any kind.
Post by: zieg85 on December 20, 2010, 11:27:38 am
The manifolds are different between the 2 years, they exit about the same way but I can't say the older exhaust would work with the 87 manifolds.  Try checking to see if they share the same y-pipe that should give you a good indication...
Post by: Grim 82 on December 20, 2010, 01:44:12 pm
O2 sensor
Post by: Bodyswap on December 20, 2010, 03:26:01 pm
If yours has an O2 sensor or a cat on it then you may want to not tamper with that if your state is strict.  Here in good ole arkansas they are very lax with the enforcement of the laws.  If you lived here I would say "laws?? You mean guidelines?" then point you to a muffler shop that does great work.
Post by: topp on December 20, 2010, 03:53:06 pm
O2 sensor
O2 sensor can be added with a weld in bung.....
Post by: three8six on December 20, 2010, 04:10:11 pm
Ill say where Im at in Florida they are mega relaxed, and in Florida we are in general relaxed until you get into the larger cities.  Emissions smhisshions.
Post by: Grim 82 on December 20, 2010, 04:18:25 pm
Indeed the O2 can be added, and I'm guessing that's the only reason that the kit's not listed for the 87 since it wouldn't be a direct bolt on. Cherry Bomb glasspacks are only about $25 a piece, and if you can find somebody to bend and weld the pipe for you it would be a much better exhaust system than the clamping pieces together setup that's in that kit. Also Chris does sell an exhaust system for 2wd trucks on this site, but it's set up for long tube headers, which by the way, would be a great upgrade. I run long tube headers, 2.5" duals with 24" glasspacks and I think it sounds great.
Post by: crunchie on December 20, 2010, 04:27:46 pm
I'll have to check again tonight but I believe the O2 sensor is in the base of the manifold, and not involved with the down pipes in any way.
I definitely want to keep the O2 sensor there for closed loop control of air/fuel ratio!
Post by: crunchie on December 20, 2010, 04:37:02 pm
Hmm, there's an idea. I didn't want to spend too much on this project, but hey, it happens sometimes.
Do you have any issues with keeping the screws tight at the cylinder head to header flange joint? Or any trouble blowing out exhaust gaskets there? I have headers on my Oldsmobile, and I have to check the screws every 1000 miles or so because they loosen up and blow out gaskets about once a year if I don't. They are Hooker Super Comps, so they have good thickness to the flange, but the screws are 3/8" dia by 3/4" long, which is just on the edge of being too short for a good bolted joint. A rule of thumb is that in order to maintain clamp load, a screw should be more than 2x longer than its diameter, and in an area such as exhaust which is subject to significant vibration and thermal cycling, it probably needs longer screws. I haven't tried anything yet, been too busy remodeling a house.
If you have a solution, I'm interested to hear about it.
Post by: VileZambonie on December 20, 2010, 04:40:47 pm
O2 sensor
Guys the O2 sensor is in the manifold not the pipe.
Post by: topp on December 20, 2010, 04:55:18 pm
It's not listed for an 87 because of several reasons:
It's pre bent, and if I remember right, there were some changes to Chevy trucks and their frames at some point ( I know for a fact the K5 series had changes to the floor layout).
87 has cats, the kit does not allow for that (of course you can cut and install yourself)
87 is an oddball year.  The new truck body style came out in 88 and 87 was the first year of Fuel Injection in these trucks. When it comes to parts (headers, etc...) 87 is the red headed step child.  You'll find listings for up to 86, and from 88 on....
Post by: Grim 82 on December 20, 2010, 05:00:19 pm
Yes. I have Flowtech's and I re-tighten the bolts every other gas filling session. Haven't had any trouble with the gaskets except at the collector. I put aluminum ones in and they have held up so far.
Post by: crunchie on December 20, 2010, 06:02:24 pm
Good to know about the aluminum gaskets. Thanks.
Post by: Bodyswap on December 21, 2010, 04:37:13 pm
Get longer bolts and lock washers.  Worked great on my cutlass, never had a problem after that. Also, what I did on my 85 is cut the flanges.  I never had any problems there either.
Post by: bobcooter on December 21, 2010, 07:08:44 pm
 I had good luck with the copper header and collector gaskets from Summit.
Post by: Big Blue 87 on January 01, 2011, 04:44:17 pm
i live in arkansas to..rural arkansas. honestly ive never heard of any emission laws enforced here lol. i run true dual straight pipes on my truck lol
Post by: Psycho71 on January 01, 2011, 08:44:48 pm
My wife and I got married in Arkansas. About two months later they sent us a letter telling us that unless we could provide proof of a shared bloodline somewhere in our family tree they would annul the marriage.  ;D
Back tot he topic; Here in Tx, anything older than 25yrs is subject to safety inspection only, even in emission counties.
Post by: Big Blue 87 on January 01, 2011, 09:11:18 pm
emissions laws aint there for me to worry bout...its gettin in trouble for disturbin the peace lol ive heard the cops in town dnt like my exhaust alredy lol
Post by: KY..Rob on January 01, 2011, 10:42:08 pm
Now that's Funny!! I don't care who ya are ;D
Same here in Kentucky, pretty laxed. Although we have had a rash of converter thefts..I guess they bring high dollar at the salvage yards.
Post by: Big Blue 87 on January 01, 2011, 11:16:04 pm
[Now that's Funny!! I don't care who ya are ;D
[/quote]
yep. some types of converters are worth something..some aint worth nothin
