73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: CanadianC10 on December 20, 2010, 09:48:08 pm
Title: Axle Spline?
Post by: CanadianC10 on December 20, 2010, 09:48:08 pm
Hey guys , I was wondering if the 6 lug axle from a 4wd and the 5 lug axle from a 2wd have the same spline , I have a posi unit in a parts 4 wheel drive that I was hoping to put in my 2 wheel drive truck , I want to stay away from carrying 2 spare tires , I was hoping I could swap the axles and keep the 5 lug all round
Thanks , Brennan.
Title: Re: Axle Spline?
Post by: Irish_Alley on December 21, 2010, 12:23:28 am
As long as it’s the same type of axle it should be a swap. You should be able to also swap the brake back plate and all
Post by: KY..Rob on December 22, 2010, 09:57:45 pm
Your spline count should be 28 on both axles if their 10 bolt differintials. 30 spline on the 12 bolt Diffs. The difference is going to be in the length. 2wd 10 bolt 5lug 28 spline = 31 3/8"  4wd 10 bolt 6 lug 28 spline = 31 5/16"
2wd 12 bolt 5 lug 30 spline = 31 5/16"  4wd 12 bolt 6 lug 30 spline = 31 9/32"
Post by: topp on December 22, 2010, 10:12:20 pm
The 4WD 10 Bolt had 2 sets of splines counts AFAIK.
28 for certain years and 30 for certain years (at least on the K5).
Up to 87 for front 10 bolts was 28 spline, and 88-91 was 30
The rear was always 30 spline
