73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: seventyx3 on January 05, 2011, 08:51:19 pm
Could a four wheel drive blazer be converted to 2wd with the front crossmember spindles, box, etc. from a 2wd truck as a direct bolt on? 2wd blazers are rare, but four wheelers are common. Would this also affect drive shaft length?
The front can, the rear cannot. BUT you can lower the rear of the blazer some and make it 4x2. Driveshaft would be different as you would have to get a 4x2 driveshaft.
I am gathering parts now to convert my 4x4 Blazer to 4x2. (I also could go the easy route as I already have a 4x2 Jimmy)
Would I still need to find a 2wd blazer reared (leaf springs) to make it "normal"? What would be the best way to lower it? I'm wanting a factory ride height.
Factory ride height you should be fine with the 4x4 stuff, just may need lower springs.
Out of the box idea here.
Could you just "lower" the whole 4x4 and make it a lowrider. Adjust all the drive shafts and put on street wheels/tires. Go for a sleeper look that could be funtional in city snow, like an AWD car.
NO lowering a solid axle is not possible.
I don't see why you couldn't do a flip kit front and rear. You would have to adjust your steering, shorten shafts ect.
Even if that was possible, it would put the steering in the middle of the axle tube. Trust me, lowering a 4x4 is not possible.
Capt is right, there isn't any way to lower a straight axle 4x4, cept for maybe hydrualic steering, even then... why?
Ok ok... guess that idea was waaaay too far "out of the box" :).
You make good points with the solid axle thing. It was way too late to think properly, couldn't sleep (couldn't think either).
Make it a 60's gasser tribute, you can make it 2wd or 4wd and keep solid axles, leafs ect. That would be outrageous, fender headers, mag wheels.
