General Site Info => Welcome => Topic started by: lmbrjack on January 11, 2011, 07:30:17 pm
Title: wandering steering 86 Chev K-20
Post by: lmbrjack on January 11, 2011, 07:30:17 pm
Can someone please help an old guy that is about broke and does not know what to do next?  I bought an 86 Chev K-20 that I want to restore, but first, I want to get it driveable. It wanders from side to side when driving on uneven pavement. I have replaced ball joints, tie rod ends, drag links, repacked wheel bearings,rag joint good,steering column has no play.  Replaced tires, front end alignment,replaced steering box 4 times--2 from Auto Zone, and 2 from local Chevy dealer--all remans.(can't find new old stock); replaced all spring bushings and shackles. When motor is off, there is about 2 1/2 to 3inches of play before the wheels start to move; with engine running, there is about 2-2 1/2 inches before the wheels start turning; I give up!  I took it to local Chevy dealer; for $80 he would do a diagnostic on steering and suspension.  Dealer said front not in alignment with back end. He said from left side to right side. there was 1  inch difference in  between front and back. I do not believe that this would cause play in the steering;  Steering works easy.  I was wandering if the pump would have enough pressure to make the steering work, but not enough to keep the play out when the motor is running. Please help!
Title: Re: wandering steering 86 Chev K-20
Post by: Irish_Alley on January 11, 2011, 07:47:50 pm
How bad does it wander. When its off and you turn the steering wheel wheres the slop at before the wheel turns. Myabe its be but a stock wheel 3" of play doesn't seam much
Post by: lmbrjack on January 11, 2011, 07:59:21 pm
It will wander across the lane if you let it.
Post by: zieg85 on January 11, 2011, 08:01:11 pm
Has the front axle u-joints been checked?  If they are frozen this could contribute to your problem.
Post by: lmbrjack on January 11, 2011, 08:07:28 pm
axle u joints are fine; had them out when repacking wheel bearings and changed the ball joints.
Post by: Irish_Alley on January 11, 2011, 08:08:42 pm
Does it pull or just goes wherever it wants due to the road
Post by: zieg85 on January 11, 2011, 08:10:39 pm
Bias ply tires?
Post by: lmbrjack on January 11, 2011, 08:11:49 pm
Goes wherever wants
Post by: lmbrjack on January 11, 2011, 08:12:39 pm
Radial 10 ply mud and snow, new
Post by: topp on January 11, 2011, 08:23:23 pm
Check the rag joint. While someone else turns the wheel letting you know when they start turning, until you see the box start turning.  You'll find play there.
Also, check the steering box to frame bolts, and behind the box for cracks.
Both of these problems will cause wander like that on a K series vehicle.
Post by: lmbrjack on January 11, 2011, 08:29:49 pm
Rag joint is in good shape--no play; changed box4times; frame is perfect, no cracks;
Post by: zieg85 on January 11, 2011, 08:47:57 pm
If your caster and camber readings are close to zero that would also cause wandering.
Post by: VileZambonie on January 11, 2011, 09:07:54 pm
You gave the answer to your problem in your description. You said you can turn the wheel back and forth about 2.5 inches before the wheel moves. That's too much play. Have an assistant rock the wheel back and forth while you observe the steering shaft, the coupler, the pitman arm, the drag link, steering arm etc.
Post by: lmbrjack on January 15, 2011, 10:34:12 am
I checked steering column, rag joint;  The play is in the steering box itself. I changed it 4 times already.  None of them corrected the problem.  Is it possible that the steering pump itself is producing enough pressure to make the steering easy but not to take the play out? Is there a way to check pressure reading on the pump and what should that pressure reading be?
Post by: VileZambonie on January 15, 2011, 10:38:27 am
Pump pressure has nothing to do with play. The truck should be off with the wheels on the ground when you do a dry park check. Have an assistant rock the wheel back and forth and if you see the shaft rotating but the pitman arm isn't moving (wheels pointed straight ahead) then yes the play is in the box. Check it again.
Post by: lmbrjack on January 15, 2011, 11:04:46 am
What is the proper procedure for adjusting the reman box, as this is the 4th box I have replaced.  The problem is exactly as you described.
Post by: Big Katz on January 19, 2011, 09:39:58 am
If your slop is in the gearbox, have you tried andjusting the backlash in the steering box gears? It is the allen bolt with the lock nut on it. If I remember right you loosen the jam nut and turn the allen clock wise. I wouldn't turn it more than an 1/8th of a turn at a time. Then go for a test drive and see if you are satisfied with the amount of play in the box. Don't get crazy with it. It will ruin the box in a hurry if you have it too tight.
Post by: Captkaos on January 19, 2011, 01:24:18 pm
Have you verified where the slop is coming from?  I wouldn't think the steering box is causing this.  The adjusting nut is for gear preload.
Post by: thirsty on January 19, 2011, 06:39:25 pm
I would look at the drag link.
Post by: VileZambonie on January 19, 2011, 07:41:36 pm
If you are positive you have the right rag joint coupler on the box (there are different sizes) and that the play is in the box adjust the high point on the gear box. Point the wheels straight ahead, witness mark the adjuster, loosen the jam nut hold the lash adjuster from moving. Rock the steering shaft back and forth while observing the movement of the sector shaft or pitman arm. Incrementally rotate the adjuster lash clockwise until minimal lash is achieved. Tighten the jam nut while holding the lash adjuster from moving and try it out. Do not overdo it.
Post by: lmbrjack on January 23, 2011, 07:44:19 pm
I learned on the internet from another site, that reman steering boxes are not the way to go.  Go to PSC and order a new one.  Took care of the problem.  I am very satisified.  Thanks for all of your help.
Post by: Dr_Snooz on January 23, 2011, 09:29:02 pm
You might also have a problem in the back end. If the rear wheels aren't tracking straight, or are shifting around, you can get some interesting steering issues.
Post by: Irish_Alley on January 23, 2011, 11:47:12 pm
My 94 is doing the same thing today I noticed the pitman arm is bad it rocks side to side
Post by: farmerchris on January 31, 2011, 12:53:54 pm
lot of the reman boxes are notorious for this.when rebuilding the old box you are suppose to center the sector shaft and adjust preload with a inch pound torque wrench .they put a quick adjust on the preload and ship them out call them good.then they have slop when you put them on.
