General Site Info => General Discussion => Topic started by: clubbert on March 02, 2003, 10:09:00 pm
I Want to switch to to a tilt steering column in my truck but not sure what all in need. Do I need the entire column including shaft and all or just the housing up. Also I noticed that there are two different ones in some catalogs one for
73-78 and one for 79-87. anyone know the diff? and which would I go by considering I have a 74 frame and a 82 body?
thanks
c
Go with the year your cab is. The diference is that the wipers are in the directional switch handle on the newer trucks.
Does a tilt column give you more room between you (stomach) and the steering wheel. i feel so close when i drive.. Do they make different offsets in steering wheels !!!
Good luck with the column...
Jason
