General Site Info => General Discussion => Topic started by: noctech on April 13, 2003, 08:08:00 pm
Title: transfer case leaks
Post by: noctech on April 13, 2003, 08:08:00 pm
I need some info on fixing a leak from my transfer case on my chevy blazer and what  kind of fluid goes in it.
Edited by: noctech at: 4/13/03 8:09:45 pm
Title: Re: transfer case leaks
Post by: RSBAD454 on April 14, 2003, 10:26:00 am
where is it leaking, and do you have a shop manual to reference to?
Toys are my game
Post by: noctech on April 14, 2003, 01:30:00 pm
Its leaking from the front seal it looks like to me you can see where it is wet ariund a bolt and no the thing didnt come with any manuels, any info would help i think it is tranny fluid that goes in it but Iam no sure
Post by: noctech on April 14, 2003, 01:32:00 pm
Also is it a tie rod or a sway bar that is on the front, it looks like a tie rod but i have heard both, it does connect the two front tires together.
Post by: RSBAD454 on April 14, 2003, 03:29:00 pm
well you can tell whether or not its a tie rod or a sway bar.......a sway bar ties both wheels together to keep the trucks body from rolling in a corner, and a tir rod connects to the steering knuckle on either side so you are able to turn. you should invest in a chiltons or haynes shop manual so you can reference them for help. pop the drain plug off the transfer case and see what fluid runs out then you ll know.
Toys are my game
Post by: Sierra4x4 on April 14, 2003, 11:35:00 pm
well what weight oil do you put in the np 205? and where do you put it in at?
Post by: RSBAD454 on April 15, 2003, 08:45:00 am
im not a 4x4 expert so you may want to ask the 4 wheeler guys...........you really need a shop manual.
Toys are my game
Post by: Kevin108 on April 15, 2003, 05:09:00 pm
Yeah some kind of reference manuals are definitely in order here.
Chilton's makes the best aftermarket books.
Haynes manuals are okay once you know how to use them.
Most parts stores carry these two types.
Amazon.com has them as well.
Original Shop Manuals are the best but are usually quite expensive.
87 Silverado ½-ton 4x4 Longbed Pickup
350 TBI, 700R4 w/ Corvette servo
4" Skyjacker, 33x12.50s
14-bolt rear & Detroit coming soon
My Mods | Truck Pics | Kevin108@PavementSucks.com
Post by: RSBAD454 on April 16, 2003, 09:33:00 am
i looked on helmsinc but did not see any factory manuals which sucks......
Toys are my game
Title: NP 205 Gear oil
Post by: 73K20 on April 16, 2003, 09:50:00 am
You want to run 80w-90 gear lube in a NP 205.
1973 K20 - 350/350/205
Title: Re: NP 205 Gear oil
Post by: Kevin108 on April 16, 2003, 04:24:00 pm
I think for our trucks Helm only carrys 80 up.  That's why I recommended the other two.  Hope this helps!
