73-87 Chevy _ GMC Trucks => Performance => Topic started by: autofreak on March 06, 2011, 10:30:44 am
hey guys i have an 87 swb 4x4 with a 350 out of a 71 chevelle, and a 4spd. I would like to go to a tpi system my question is what years should I be looking for, should I look for the corvette or camaro style. and how difficult is this swap as i know nothing about fuel injection. I know that I will need the computer and wiring, intake, and fuel pump. Is there any thing else i need to watch out for? Any help would be greatly appreciated. thanks
You need the early style that will bolt up to the old block, but I suggest getting the later upper section without the 9th injector and use the later model ECM. It is going to be easier to just buy a complete setup that is refurb'd in my opinion. Been there, done that...
And you'll need a Fuelie Tank with baffles...
thanks guys for the info. i found a good deal for a setup off a 87 iroc. computer wiring the whole shmeer. im hoping it works
Intake will need to be adapted to go on "normal" heads.
are the center bolt heads different. what would I need to do to make it fit
