General Site Info => General Discussion => Topic started by: 1979C20 on April 07, 2011, 04:07:17 pm
I call my truck the titanic because of the 2 huge foot long dents/creases on the passenger side. So I wanted to get it as a license plate. These are the options available. Cast you vote or suggest some! Thanks guys.
"Others, like Arizona and Kansas, issue two plates but make rear display required and front display optional. Most other states issue only a single plate for the rear of the vehicle.
Read more: U.S. Laws on Front License Plates | eHow.com http://www.ehow.com/about_5250734_u_s_-laws-front-license-plates.html#ixzz1IsHqhz36"
I pulled this up from your laws in AZ.... Why don't you just spell it like it is supposed to and have one made and display it on the front???
Rear plate required. If he gets the new plate, the old plate will be void, so the current plate will need to be on the rear.
I meant something someone would airbrush at a shopping mall, not an actual AZ license plate...
Well, the reason I cant get it the way its supposed to be spelled is because somebody already has TITANIC registered to a vehicle in Arizona. And I like the standard Arizona plate.
can you get TITAN1C ? T1TANIC ? T1TAN1C is starting to push it, but you still read it as titanic before you catch the ones.
Sadly, I tried all of those and they were already registered.
I personaly like it spelled just a little off for license plates. Makes people stare at ya. :P
