73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: mach1mustang351 on April 08, 2011, 11:49:59 pm
Hello. I have been searching for a while and I can't find it. I was wondering if there is an issue hooking up the shift column linkage when swapping the T350 to a 700R4. Are the detents in the shifter column able to work with the extra shift position of the overdrive trans?? Also will the T case shifter have to be modified after the swap?? Thanks
Thought you had to switch columns also
There are no "detents" in the column...The shifter just slides freely through the arch of motion. The detents that you feel are in the transmission. A roller assembly rides over a toothed paw.
Some guys have said they couldn't get Low 1 when changing from a TH350 to the 700. I'm not sure if there are something like cab sagging issues that may be involved. I didn't have any trouble when I did mine...I just tweaked the z-bar a bit to clear the header & have all gear positions.
I'm not a real 4x4 expert so someone else can correct me if I'm wrong, however the transmission output shaft is the same spline & the 4 tail housing bolts are the same pattern...so if you have a 4x4 700, I'd guess it's a go. Hope this helps, Lorne
haulin is right about the output shaft and the adapter plates look similar but not sure. dont know what i was thinking about the columns but now since he said that it makes more sense that way
