73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 1fishinrogers on April 16, 2011, 12:56:09 pm
while I was changing the fuel filter on my 87 silerado, I noticed a 3/16 hose adapter fitting on the top of the transmission with nothing hooked to it. I know the older models used vacuum to shift but not sure about 87, I don't see anything resembling a modulator valve. Is it a vent line connection or other ? Thanks
It's the vent. It should be directed away from the exhaust in the event that the trans overheats it could vent to the catalytic converter and catch on fire.
thanks, I'll fix that stat.
