73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Bluesmoke907 on May 08, 2011, 05:37:34 am
I have a 1983 chevy c10 2wd long bed 1/2 ton originally came with the 5.0 305, I bought the truck no engine no transmission and now I need help figuring out what transmission it came with from the factory if you anyone could help me out that would be greatly apprecited
not sure about the trans but what do you see in the gear selector window (how many gears)
I know it had an automatic but as far as the gear selector it is not there. Dash and steering column was removed from the truck when I bought it
do you have the RPO sheet in the glove box?
No there is no rpo sheet in the glove box
Since it had a 305 I bet it came with a th350? Maybe you could measure the length if the drivelin ed and people in the forum can measure theirs and say which transmission they have and you could find out that way?
I'd be very surprised if you could get a 305 with anything but a 700R4 in a c10 in '83. My '83 Silverado originally had a 305/700R4.
I didnt even think of the 700r4. As a matter of fact my friend has an 84 That originally had a 305/700r4. Now has a crate 350 and same trans. Once again, Maybe a drive line measurement can decide for sure?
Presence of a low vacuum switch on the firewall and the wiring for the convertor lockup would point towards it being a 700r4.
Also where the cross member is located can point to what trans
The presence of the vacuum switch is not really indicative of anything. My 1984 sierra classic originally came with a th350c and had the switch.
My 85 has a 305/TH350C combo
my 80 has A 350/th350 in it. I would just put a 700r4 in it so you can have overdrive in it.
So if my 84 swb has a d and d in a circle. Does that mean it came with a 700 from the factory. Should it be 59 inches from the seal to rear end
That indicates a 700R4 with the gear selector you describe. Don't know the overall length but a TH350C is the same length.
Thanks i put a 350/700 in it that's my only hold up. I was worring about the driveshaft working. I measured the driveshaft with the yoke it was 60 inches will this meet the clearances.
