73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 1978 K20 on May 16, 2011, 01:45:14 am
So here is the deal.
I've got a 78 K20, The right brake light is having problems. First thing I did is changed the bulb (twice) and still nothing. The weird part is that there is power to the socket. It is a 1157, so it is dual filament. When only the tail light is only on there is power to one side, and when I press the brake pedal there is power to both sides (like there should be.) BUT THE LIGHT STILL ISNT WORKING!
It wasn't working last night, yet it worked when I left work, and didnt work when I backed into my driveway (2ish miles away.)
ANY ideas are welcome. Thanks!
-John
bad ground
But where is a ground in that circut?
(http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/77-80_chass_rr_light.jpg)
could also be a bad socket
Unless I have gotten two bad sockets in a row, I am ruling out a bad socket. I think my best bet is going to be to shoot wiring and try to find a bad ground.
did you change the bulbs and sockets or just the bulbs
If you think its a bad ground runa jumper wire from the the housing to a good ground and see if it works.
You can count on Vile for a solid answer. I would have said to run the jumpers into the left brake light and call it a day.
