73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: the_legend_1981 on May 19, 2011, 05:22:34 pm
Title: power steering whine
Post by: the_legend_1981 on May 19, 2011, 05:22:34 pm
Ok this isnt 73-87 but i have a 94 chevy 1500 with 305. the power steering is whining at an idle and i can hear it in 1st and 2nd. The whine does not increase when turning the wheel. Should I try bleeding it? is there common problems with the tbi?
Title: Re: power steering whine
Post by: Lt.Del on May 19, 2011, 06:41:49 pm
sounds like the pump is going.  The same sound will happen when the belt tensioner bearings are about to go too, so, be sure it is the pump.
Post by: the_legend_1981 on May 19, 2011, 06:57:11 pm
how much work is it to change the tensioner?
Post by: the_legend_1981 on May 19, 2011, 08:15:06 pm
is there a way to regrease this?
Post by: Lt.Del on May 19, 2011, 08:18:31 pm
they're usually sealed units.  AFter removing the belt, You'd have to look at it.  I don't know the setup of a 94, but, there should be a pulley with bearings.  There should be a bolt through the middle or the spring bracket that is held by 2 or 3 bolts..you'd have to look at it.   Still, it could be your p.s pump.  Be sure prior to replacing things.
Post by: the_legend_1981 on May 19, 2011, 08:34:56 pm
ok. thank you
Post by: the_legend_1981 on May 19, 2011, 08:39:46 pm
doesnt sound like its coming from the power steering side so i'll take the belt off tomorrow and see whats up.
Post by: the_legend_1981 on May 20, 2011, 06:07:28 pm
exactly what it was...thanks again
Post by: Lt.Del on May 20, 2011, 08:11:14 pm
glad to help.
