73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 84scottsdale454 on May 28, 2011, 10:47:43 am
i have a stock 454 installed with a turbo350 trans, i cant look at my gears at this time......can someone give me an idea on what they will be? i think this rear end was custom built before i bought it! any ideas?????????
what kind of rpm are you turning at 79mph, or 60mph, or whatever? Tire size will ploy a role in that as well. With both of those figures, and the 1:1 thrid gear of the th350, it's just math to get the rear end ratio.
unsure of the rpm, it was the max rpm because thats all it could take....i could not go 80mph! the tires size are the stock height
You have given nowhere near enough information for anyone to even venture a guess and at that all you will be getting are random guesses.
yep
Shove a $30 dollar tach in there and get a rpm reading. Then please report back with rpms and the actual tire size. Stock doesn't help in the slightest.
your a smart man slammed79..... imma get a tach, me and the ol man pulled it out today, they were 4.56s! well thats what he says anyway! i appreciate your help! i dont know much when it comes to things like this! i wish i could get a pic on here, my truck is 1 of a kind! thanks again
count the teeth of the pinion and ring, then divide one into the other to get the gear ratio, but it should be stamped on the ring.
Why count it stamped in the ring gear tooth count
thats why I said it should be stamped....
driven over drive = :1
Your speedometer could be wrong if the rear end gears are different than stock. What type of phone do you have? If you have an android phone, download a gps speedometer and check your speed with that.
I used 2 diff speedometers on my droid phone! I'm sure any idiot could determine they were low,thanks for the reply "79"! Now I'm runnin 3.08s and they seem perfect! I can't still smoke the 22s at 20mph kickdown
4.56s even with a 26" tire and 79 mph should be about 3800 rpm. if your engine wont turn past that you may have some MAJOR issues. i think the "buy a tach" advice was the best thing said to this point.
i dont feel the need to buy on tachs look TACH-Y, i know how to blow a motor up and to keep from doing it. i solved the problem with 3.08s and my motor runs flawless and is practically new so maybe my phone is a turd or something! either way THIS MAN IS HAPPY LOL
