73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: Garrettsdad on May 30, 2011, 01:12:13 pm
Title: Rear slider removal??
Post by: Garrettsdad on May 30, 2011, 01:12:13 pm
What is the best way to remove a rear slider? Do you need special tools?   Thanks chris
Title: Re: Rear slider removal??
Post by: beastie_3 on May 30, 2011, 02:20:44 pm
It gets pushed out from the inside. Go easy and a little at a time. Fold the outer edge of the gasket so you can get it past the pinch weld.
Post by: PromiseKeeper on May 31, 2011, 09:06:24 pm
I'd pull the gasket back a bit and lube things up with some spray window cleaner too. Just dont use anything petrolium based or you'll swell your rubber up.
Post by: VileZambonie on May 31, 2011, 09:10:21 pm
If the rubber is rock hard and old your best bet is to buy a new seal and slice the old gasket, then push the window out. If the gasket is still in good shape, soapy water and a thin piece of roap or coated wire to work the assembly outward from the window frame.
Post by: kevin53garcia on June 02, 2011, 07:22:08 am
I do exactly same......
But just aware of the petroleum part, so thanks for that!!!
