73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: greeneon_01 on June 21, 2011, 09:50:58 pm
Title: 88 tbi suburban running rough
Post by: greeneon_01 on June 21, 2011, 09:50:58 pm
hey guys i apologize if ive asked a question that has already been answered on here. a few weeks ago my suburban started running rough. its tbi setup with 700r4 trans. most of time it starts out running rough but ive noticed sometimes it runs ok then after driving awhile it acts like its got a miss or slightly out of time. it starts and idles fine. its never died or stumbled. just acts like its running rough. ive also noticed it puffs out alot of white smoke when its running rough. ive changed plugs,wires,cap,rotor,iac valve,tps sensor, pcv valve and fuel filter. ive checked the injectors and they seem like they have a decent pattern and spray good. ive sprayed wd40 and checked for leaks on the hoses and intake...none. could it be the vaccuum lines down by the trans? or map sensor or coil? could it be weak fuel pressure? or the pcm? it ran fine before so i dont think its a timing issue. and ive tripled checked my firing order on the plug wires. anybody got any ideas????
Title: Re: 88 tbi suburban running rough
Post by: topp on June 22, 2011, 12:19:10 pm
Does it happen when you are giving it throttle?
Does it happen only when the engine is cold or hot?
Post by: greeneon_01 on June 22, 2011, 05:50:19 pm
it does it all the time..right from start up...or itll run fine for awhile...now that i think about it i noticed sometimes it starts running rough after ive layed into the throttle.
Post by: jaredts on June 22, 2011, 08:01:28 pm
Are you losing coolant?  Checked the oil for milky garbage?  Checked the plugs for one that's different?
Post by: VileZambonie on June 22, 2011, 08:10:59 pm
Make sure the EGR isn't open. Unplug the vacuum hose at the EGR valve and manually operate the diaphragm to eliminate that. Any codes?
Post by: greeneon_01 on June 22, 2011, 10:02:47 pm
how do you manually operate the egr valve? ive never had any lights come on but ill check the system and see if there are any stored codes.
Post by: greeneon_01 on June 22, 2011, 10:05:28 pm
it still has all the smog stuff on it too...could it be that? is it hard to remove all of it since i really dont need it?it still has all the smog stuff on it too...could it be that? is it hard to remove all of it since i really dont need it?
Post by: topp on June 23, 2011, 02:25:11 am
The computer will freak if you just remove all the smog stuff......
Post by: Captkaos on June 23, 2011, 12:09:35 pm
Push up on the diaphram while the truck is running.
Does the SES light come on when you start it?
Post by: greeneon_01 on July 06, 2011, 11:40:50 am
I'm not losing any coolant and the oil looks good and clean. All the plugs are the same. The ses light comes on breifly when I turn the key but goes off after its started.
Post by: topp on July 06, 2011, 11:50:07 am
SES when first turning the key is normal.
Does the Exhaust smell rich?
Post by: greeneon_01 on July 06, 2011, 05:39:46 pm
Yes a little...I've noticed it smokes a lot more too...there's oil starting to collect on the tailpipe that never did before. It always smoked a little because of valve seals though so I don't know if that's related or not.
Post by: greeneon_01 on August 01, 2011, 07:32:19 pm
ok so i checked the codes and it pulled up a code 13 which i looked up and it said it was an open 02 sensor circuit. Being as everything else on the suburban is original im assuming the o2 sensor was too so i replaced it. but it still runs a little rough but doesnt cut out near as much. Ive noticed now that it runs better when its cold than after its warmed up. Also noticed i now have a hole in the muffler from a big rust hole that mysteriously popped up. (the muffler was in good shape no more than 6 months ago.) Could it be a vaccum leak or could the muffler be clogged up causing overheating in the muffler essentially making the hole...or being clogged causing the 02 sensor to read wrong? temperature seems to be reading ok so i dont think its a temp sensor. I'm not sure what else to do.....
Post by: 87suburban on August 02, 2011, 10:19:51 pm
well pulled the oil pan off the 6.2 an noticed what looks like cracks but the outer bolts for the mains, which now has me somewhat a little discouraged. Anyway, to repair those cracks i'd have to take it to a machine shop to have that done wouldnt i? also, does anyone know of a machine shop around the wheeling/pittsburgh area that has experience in machining an rebuilding the 6.2?
Post by: Dr_Snooz on August 03, 2011, 11:49:10 pm
Having too much oil in the crankcase can cause random puffs of smoke to come out the tailpipe. What do they smell like?
Post by: VileZambonie on August 07, 2011, 10:55:35 am
Quote
The ECM doesn't even look at the O2 sensor until it goes into closed loop so replacing the O2 sensor would not make it better when it's cold. Clear your codes and see what comes back. Go back to basics,
Tune up, make sure EGR is closed at idle, good fuel pressure, then see how it behaves. If it's still acting up you'll need to do some pinpoint tests.
Post by: greeneon_01 on August 20, 2011, 04:55:18 pm
sorry for the late response. figured out i had three fouled plugs that eventually ruined my o2 sensor. and i had a couple small vacuum leaks. all in all i dont see how it even ran lol. well it ran great for about a week. then started idling rough. it has a low idle and it lopes like it has a big cam in it. sometimes it almost dies out but has never died on me yet. ive noticed driving down the road just barely on the gas i can feel it lope and surge lightly. any ideas? it runs great otherwise. and no codes or cel at this time. im stumped.......
