73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: aaront on June 29, 2011, 01:50:33 pm
Some manufacturers show two kits, one for 73-76 and one for 77-87. But other manufacturers show only one kit for 73-87. What changed in '77?
Size of the front u-bolts maybe?
There were a ton of changes all over the trucks from 1976 production to 1977 production, one of which was a heavier front axle housing on the 4x4 models.
Some lift kit manufacturers may just send u-bolts that fit both, whereas others send u-bolts that have an exact fit.
Thats the year Gm switched from the Dana 44 front to the 10 bolt.
but that doesnt matter as far as lifts go. axles almost identical.
I think it has to do with the size of the bolt & bushing size of the front spring shackle. GM changed the size of the bolt hole on the shackle at some point. Some of the springs that say they fit 73-87 come with 2sets of bushings you can swap out to fit your truck.
Really???...My '77 K20 has a D44 front.
Just cause your truck says its a 77 don't mean it was built in 77 think about nowadays when about fall you can buy a 2012.
It has been a long-standing tradition that automobiles have a new model year starting in the 4th quarter of the preceeding year. That is nothing new!
My '77 K20 has a VIN that says it is a 1977, was built in Janesville and was the 61,333 truck of the year. My 1977 factory service manual also says that it has a D44. If it was a K10 I think then it would have had a 10-bolt, but I would have to re-check my books.
Anyways...sorry to hijack the thread.
a D44 is available in 1/2 and 3/4 ton.
and so is the 10 bolt to 77+
i know this doesnt help you out much but i have a kit that was on a 75 k5 on my 85 gmc truck. everything fit like it was suspost to.
Comparing Procomp kits on Summit racing, the only difference is the front ubolts. It shows 73-76 with a 3" axle tube and the 77-87 with a 2.960" axle tube. Now, I know my 76 with a D44 has the second design tierod and the axle tube measures 2.960". I don't know if the front axle is original, because I know the rear isn't. The rear is a 12 bolt G80 3.73 and the front is D44 3.07. My plans are to put 3.73s in the front, 4 inch lift with 33's, and part-time the NP203.
