73-87 Chevy _ GMC Trucks => Performance => Topic started by: str8bloc on August 21, 2011, 08:16:32 pm
i got a complete rebuild qjet for a set of rallies. it came fm an 80 4x4 454 will it work on my 305 or what
yes
so just gotta tune it sweet . goes on thursday
It'll work, but the jets, metering rods, spring hangers, just about everything will be a far cry from the quadrajet GM would have put on your 305. Air/fuel ratio won't be perfect, but might be o.k. with a little tuning. All that stuff can be changed out anyway.
I put a 305 qjet on a 366 tall deck once... worked beautifully! 5.0 to 6.0 with absolutly nothing done to it aside from adjusting the secondary av.
Granted a 454 is a fair bit larger.. but depending on the build and the expected rpm you may get away with minimal adjustments...rejetting and so on. Personally I would have already slapped it on and tried... why not?
